Need suggestions for a set of good headphones
Knucklehead
Knucklehead Posts: 3,602
edited April 2009 in Speakers
If I had some idea of what to look for in headphones I'd feel better about buying some rather than just giving myself a budget and buying any old set that might be a rip off.
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan
Post edited by Knucklehead on
  • TheMARPATNinja7
    TheMARPATNinja7 Posts: 150
    edited March 2009
    As much as I hate Bose for speakers, the headphones are legit. They aren't cheap and your basically paying more for the name than the sound but the only headphones I've personally listened to that sounded better than the Bose Quietcomfort set was the Dr. Dre Monsterbeats but in that case you're paying an arm and a leg.
    edited March 2009
    Get some higher end Sennheisers...they can be pricey but they're worth it!
    cnh
  • Fongolio
    Fongolio Posts: 3,516
    edited March 2009
    AKG's are a good choice too. What you need to decide is whether or not to get a closed or open design. Closed can give much bigger bass but open tend to have better SQ. However open lets more outside noise in and can be intrusive to those nearby your listening area. That said, the highest rated sounding headphones in the world are almost all open design. Also consider Grado.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • sambani
    sambani Posts: 9
    edited March 2009
    you might try the Audio Technica ATH-A700. i bought a pair a few months ago and i love them.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited March 2009
    AKG-K701.
    They need to burn in for about a week constant, but after that they are MAGIC. Can't beat 'em for the $$$. I bought a new pair on ebay for $238 delivered.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • george daniel
    george daniel Posts: 12,096
    edited March 2009
    senn HD 600's,, what are you gonna' power them with?
  • CRESCENDOPOWER
    CRESCENDOPOWER Posts: 153
    edited March 2009
    - How much do you want to spend?
    - What type of electronics do you plan on plugging them into? AM/FM portable radio, mp3 player, audio receiver, or integrated amp, portable, or dedicated CD player, portable, or home headphone amplifier etc.
    - What type of sound are you looking for? I know Polk Audio doesn’t make headphones.:(
    - Check out headphone.com for all the different types of headphones that are out there.
  • Knucklehead
    edited March 2009
    thanks guys ill check out all mentioned, I will be plugging them into my AVR and an IPOD.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • PoweredBySoy
    PoweredBySoy Posts: 5
    edited March 2009
    There's an infinite source of headphone knowledge over at www.head-fi.org/forums
  • renowilliams
    renowilliams Posts: 920
    edited March 2009
    I agree with cnh on this. I have Sennheizer HD215, which are a fairly inexpensive model and they are great.
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • randyhart420
    randyhart420 Posts: 6
    edited March 2009
    Sennheisers are quite stunning just need to get the right match for you and your set up
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2009
    The best bang for the buck pair I've run acrossed are Equation Audio RP-21. I've sold a ton of them this past year and have owned Sennheisers, AKGs and Grados that cost alot more, but deliver less. Less than $100 on the street.
    http://www.equationaudio.com/Professional/pro-eartools.htm
  • be83663
    be83663 Posts: 192
    edited March 2009
    DEFINITELY SENNHEISER HD650.
    Original manufacturer's price is $599.95.
    JR's listed price is $499.99.
    But they actually sell it at $319.99.
    It sounds awesome for a headphone, and at a good price.
    Here is the link to JR Music Store:
    http://www.jr.com/sennheiser/pe/SEN_HD650/
  • Motzart
    Motzart Posts: 1,075
    edited March 2009
    I love my Sennheiser HD280 Pro's!
    Got excellent reviews everywhere I looked.
    MSRP is $200 but can be had for as little as $75 with a lil hunting.
    Helpful info on them below.
    http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004974
    http://www.crutchfield.com/p_143HD280P/Sennheiser-HD-280-Pro.html?tp=1263
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  • skrol
    skrol Posts: 3,453
    edited March 2009
    Have a look at Grado. I really like my SR80 headphones which are about 15 years old now. Grado is releasing a update the their line (ie. SR80 is replaced by the SR80i). Right now you can find great deals on the previous model.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Knucklehead
    edited March 2009
    thanks for all of the info! are any of these noise cancelling as well?
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2009
    Bose
  • skrol
    skrol Posts: 3,453
    edited March 2009
    Scratch the Grados. They are a very open design and definitely NOT noise canceling.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Sami
    Sami Posts: 4,634
    edited March 2009
    An Ipod unfortunately will not have adequate power to drive a good set of headphones. That, or my Sennheiser HD580's are power hungry.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited March 2009
    Yeah, do your research before you buy. A lot of Senns and others sound PHENOMENAL, but if you are looking for noise-cancelling or something to use for travel, in public, etc., you want to get a closed design.
    My Senn HD580s sound great, but I had no idea how much noise they let in and out. Definitely not something you'd want for travel or in any public places. You'll hear everything around you, and everyone around will hear your music.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    Don't know anything about them but JRs is have a 50% off sell on altec lansing
    http://www.jr.com/promotions/altec-lansing-earphones/?JRSource=chemail.altec.03042009
  • Motzart
    edited March 2009
    The HD280's are definately noise cancelling!
    If you have em on with no audio you can't hear a thing.
    Could use them at a firing range for ear protection!
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    edited April 2009
    be83663 wrote: »
    They e-mailed me $350 but still very good deal. Very tempted to buy a pair.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • Ender
    Ender Posts: 603
    edited April 2009
    For closed headphones that don't require good amplification, check out the Denon D2000 or higher or the ATH A500 or above. You could also opt to go the orthodynamic headphones and grab the Yamaha HP-2 or really any of their ortho. Pretty sweet deals on those because they are cheap due to being discontinued like SDA or HD DVD, but still awesome like SDA or HD DVD.
    The aforementioned Equation RP-21 and above are solid as well as JVC HARX700 or above.
    Also, you can check out the Sony MDR-V6 or 7506 (same thing, basically).
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • polkapolka
    polkapolka Posts: 145
    edited April 2009
    fast1 wrote: »
    Hi Fast1, I actually have owned these for about 9 mos now. I like them. They are passive noise cancelling. I use them for gaming, skype, and music. I really like them. I would say they are gaming headset first, & music second. I have worn them everyday for hours on end, with no discomfort at all. I often forget that I am waring them. :)
    I would recommend: IF you want passive noise cancelling-I can hear my wife and kids talking to me when they are near me, but more than a few feet away, and it is hard to hear them. Also, the mike swivels up, but is not removable. Speaking of the mike, it is excellent. I haven't had any problem with people hearing me either in games, or on skype.
    I have owned about 5-6 sets of gaming headsets, and these are by far the best. They are also rated high by the critics, and owners alike. However, these are not audiophile grade. SQ is good, but not audiophile.
    Hope this helps,
    Matt :)
    Mitsubishi 60" HD LDP
    Polk RTI-A3 L/R
    Csi-a4 CC
    Polk CSW 10 Sub
    Pio. Elite VSX-03
    Pioneer BDP-51FD Blu-Ray
    Polk Fxi3s for surround.[/SIZE]
  • zx_toth
    zx_toth Posts: 417
    edited April 2009
    I own a pair of Senn HD650s and love them. They are however the first good quality pair that I have owned so I cant compare them to anything else. I power them with only my AVR and to my ear they sound great, though the agreement on Head-fi forum was that they require a head phone amplifier. This may be true to get the full potential out of them for critical music listening however I find they are quite sufficient.
    Some might shoot me for saying that I only use them for watching movies loud when my wife has gone to bed :o
    Zsolt
  • rayslifecycle
    rayslifecycle Posts: 511
    edited April 2009
    When i was looking for headphones - I had a budget of 100 bucks
    I use them at work plugged into a computer.
    These are closed construction but sound open and airy......
    I have heard a lot of the headphones listed and they are good.......but I would recommend these if you are looking for something cheaper then the suggested options.
    They are efficient enough to use with an I-pod, but sound way better when run off something with a little meat behind it.
    Denon AH-D1001
    http://www.usa.denon.com/ProductDetails/3785.asp
