New Products...wish DVC Subs were offered
b_knockwood
b_knockwood Posts: 15
edited July 2003 in Car Subwoofer Talk
I'd like to say that i'm happy with the new look and design of the new products that polk/momo has to offer.
But what really bother's me is that I wish that Polk had offered DVC subs in the new line...:(
I was looking forward to change my system from the 4 sealed GNX124 subs to 2-12's or 2-15's if DVC was offered, (so i can keep my 4ohm mono amp). But I think i'll just keep what I have for the time being.
Post edited by b_knockwood on
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited June 2003
    both yourself and adam k. criticized polk for the same things i saiid about 2 months ago...
    but i wont say " i told you so ".
    momo subs should be offered in D2's an D4's.
    the mid grade momo i dunno about -- but the "upper end" momo (ya thom call is "carbon momo" and "momo") the non-carbon momo should be in D2 / D4 configurations.
    anythign less than that severly limits amp choices.
    a D4 momo 12 would give the user the ability to buy a 1000 watt bridgeable class AB 2 channel that will beat the living piss out of most any class D amp... this would make the sub perform even better than "expected" and would in the long run raise the respect for the sub. -- good amps are to subs what good women are to men... they say every great guy has a great woman behind him, well every great sub has a great amp behind it -- and if you're doomed to class D then you can't do that...
    far be it form me to **** on class D -- i run SQL subs off class D amps -- dirty class D amps, but i made that choice consciously for money reasons. had i wanted to, i could have gotten D2's instead of D4's and gotten much much better amps.
    the key is the ability to make a choice.
    The Artist formerly known as PoweredByDodge
  • Systems
    Systems Posts: 14,872
    edited July 2003
    Replace your Polk subs with Kicker SL7s.. I have one 10 and it hits harder than the momo 12 it replaced in a smaller box...it is DVC
    Testing
    Testing
    Testing
