should I pull the trigger on these?
nooshinjohn
They do not have original packaging or manuals however. Is anybody out there familiar with them?
I know I will need one of Ben's ICs to make them work with my SDA's... so if he is out there and reads this, please pm me with how much for a modest setup....
Thanks guys!
Post edited by nooshinjohn on
That is a STEAL.
What do you want to know about them?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
how they compare to the 7t's...
power vs current... what to expect performance wise over my TFM-35 that currently serves as my main channel amp, and how they will match up to a rotel RMB 1095 that I am looking at for my other 5 channels....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
They are 575 wpc into 8 ohms, approximately 800 wpc into 4 ohms, and about 1100 wpc into 2 ohms. The only differences between the 7/9 models are lighted meters on the 9 and there is a slight "bump" in the bass response below 100 hz (@ 1dB). Otherwise they are the same. They are stable to at least 1 ohm.TNRabbit
Sunfire TG-IV
so i could expect to see 600+wpc at 6ohm... will I experience a significant improvement in sound quality over my current setup? How about with the Rotel for my other channels?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Well, being a tube transfer modified unit, it WILL sound different from the 35, but if it's an improvement in sound quality depends largely on your tastes in sound. I've never hear a Rotel, so don't know what to tell you there.TNRabbit
Sunfire TG-IV
