Harmony Remote
Paul in Canada
I have some buttons not working on my remote. Is there any easy fix. Bottons seem to stick.
Polk RTi 8's
Polk CSi 5
FXIA4"s
Outlaw Audio M200 x2
Denon AVR 2805
Sony CDP C345
Paradigm PW2200 Sub
Panasonic 50"
"It's futile to have a battle of wits with an unarmed person." demaples July 29/08
Polk CSi 5
FXIA4"s
Denon AVR 2805
Sony CDP C345
Paradigm PW2200 Sub
Panasonic 50"
Post edited by Paul in Canada on
what model, did something get spilled on it?Sig to be updated after dealing with the insurance company:(:(:(
My 880 remote did that also, I did a cheap repair which seemed to work ok for me. Take apart remote you will find button switches very cheap to make and was a bit turned off seeing them in there. Ok back to fix lifting up the tape film clean the pc contacts and rotate the switch disk 90 degree or so. Worked for me but I cheap and refused to buy another to replace it just for a button.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I have the Harmony 520. Thanks for the responses. If I was to try taking this thing a part would I just clean with a cloth or do I need some sort of solution and what is a switch disc?
I this a comon problem with these remotes? Thanks again.Polk RTi 8's
Polk CSi 5
FXIA4"s
Denon AVR 2805
Sony CDP C345
Paradigm PW2200 Sub
Panasonic 50"
"It's futile to have a battle of wits with an unarmed person." demaples July 29/08 -
What I'm trying to say not sure of the name they use. But think of these switches as silver disk which is concaved facing so the middle to pointed up under a tape film. This type of switch is very common but very cheaply made, and many times cause issues IMHO. It wouldn't surprise me to find them in the whole line, they are designed so you buy another remote.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Upgrade to a Harmony One which should last you yrs.Shoot the jumper.....................BALLIN.............!!!!!
Sorry but why wouldn't I feel the Harmony One doesn't use switches like that also? Switches good for 10k use no more, where the volume control is must likely to fail.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
you sure it just doesn't need batteries?
