Best motorized screen under $250?
neokeelo
I will be using a Mitsubishi HC1500 (1280x720) 2500:1 contrast, 1500 lumens
I need a screen from around 94" to 108". There are many ones to choose from on amazon and Monoprice. What kind of gain level should I opt for? Anyone have experience with these?
Thanks for any advice you can give me.
My System
Pre/Pro - Integra DTR 40.2
Amplifier -Parasound 2205a
Paradigm Studio 60s V5 Mains
Paradigm Studio 590 V5 Center
Paradigm 20s - rear ( Wanted)
SUB - SVS PB12-NSD
LG PK250 60inch Plasma
SUB - SVS PB12-NSD
Post edited by neokeelo on
www.htdepot.com I recommend focupix. Check them out.Shoot the jumper.....................BALLIN.............!!!!!
And to answer the rest of your questions, gain should be around 1.5 so a Matte White screen should do you well. Focupix screens have gotten great reviews and the customer service has been pretty good based on other's reports from AVS.
Edit: And if the budget allows I highly suggest you go for a tab-tensioned screen, so that you wont get any waves in the screen. Price goes up but is very well worth the extra coin.Shoot the jumper.....................BALLIN.............!!!!!
you think a gain of 1.3 is not enough for 1500 lumens? This projector is really bright for me. also , if i do get waves in the screen do most companies pay for the shipping to exchange for a non defective model?My System
SUB - SVS PB12-NSD
LG PK250 60inch Plasma -
1.3 gain should be plenty with that PJ. As for waves it is common for motorized screens thats why I suggest the tensioned version so you dont see waves in it when watching movies, etc.Shoot the jumper.....................BALLIN.............!!!!!
my budget is only around $200-$400 though..My System
SUB - SVS PB12-NSD
go for
http://www.htdepot.com/Focupix_Flexio_16_9_Electric_Motorized_Screen_103_p/fxo169a-100-wh.htm
http://www.htdepot.com/Focupix_Flexio_16_9_Electric_Motorized_Screen_103_p/fxo169a-100-bk.htmShoot the jumper.....................BALLIN.............!!!!!
Thanks, that last one looks nice. Its for my dad to be placed in the living room with 16ft ceilings and my mom wants something nice that can be put away that wont destroy her decorating.My System
SUB - SVS PB12-NSD
Then definitely the last one if its for the parents. They will love it, as it is a quality item. 92" inch screen is plenty big for living room setup, its pretty common size actually. When you start talking over 110" screens youre talking huge and even though the HC1500 is bright you will loose brightness, also keep in mind that most PJ bulbs dim by as much as 30% once the bulb settles. So for your application the last one will be great for that type of setup.Shoot the jumper.....................BALLIN.............!!!!!
ok, i think that one will work good. Now I just need to find some reviews of this screen..My System
SUB - SVS PB12-NSD
more than enough reviews here
http://www.avsforum.com/avs-vb/showthread.php?t=799126&highlight=focupixShoot the jumper.....................BALLIN.............!!!!!
