Audiosource AMP300.. good?
classical
hi all,
I have a chance to get for a very decent price of a combo Audiosiurce amp300 amd a Audisource Pre One..
I search but there is very little infos that can learn about the..
Are they good..? (to drive an pair of Rti10 and Rti8)
thanks a lot
thanks a lot
Post edited by classical on
I have had (and currently have) both Audiosource amps and preamps and if you can get a good deal on them, go for it. They are neutral sounding pieces of equipment that aren't overly inspiring, but strong performers for the price. Also, that amp has enough power to drive those, so that won't be a problem. They are a great combo that I used for a while until I built my own equipment.
PS. I have a Pre One for sale that I could beat your price on...
thanks Zingo,
I just send you a p.m. -
Any polkies using this amp?
What do you think?
Seems like a cheap amp with good specs. -
I have two of these, and an amp200. My first 4 ohm speakers were the Lsi9's and my receiver just did not open them up. I then got the first amp300 to help but wanted to conserve my money for an LsiC and eventually the Lsi25's. the amp300 worked like a charm on the 9's and I bought another one after the purchase of the 25's and the amp200 for the center to get better dialog - it worked great.
currently - in the living room - for a stereo set up - I am using the two amp300's in bridged mode to power a single Lsi25 each. I am using a Yamaharxv661 in biamp mode / splitting the right and left chanels from the receiver so that two L imputs go into the L amp300 and two R imputs go into the R amp 300. the surround back chanels also output the front chanels in biamp mode - which i use to run R and L RCA lines into the line ins of the active/woofer part of the Lsi25.
I know that there are better amps out there and I will eventually check them all out (kids want a new boat right now), but for records and SACD listening, this set up sounds out of this world to my ears - which have been at this for about 2 years now.:D
in a surround set up in another room - the amp200 is also in bridged mode, and running an LsiC. the volume setting on the amp200 has to be set to half way or it will drive the LsiC much harder than the amps powering the mains and the surrounds. I am using a Niles2125 to run the 9's in this room and a yamaharxv863 to drive some Lsi7's for surrounds.pop
media room: Lsi25 mains driven by an audiosource amp300, LSi9's driven by another amp300, LsiC drivin by an audiosourcAmp200, Lsi7 rear channels driven by receiver - Yamaha 863, Panamax 5300, epson 6100 w/ 106" elite cinatension2 screen, HPz555 media center, oppo 980, techniques SLbd3 turntable,xbox and ps3,
living room: VM30 mains driven by a niles 2125, VM20 center and VM10 surrounds, velodyne dsp10, yamaha rxv661, cambridge audio dvd89, panamax5300, philips 42" plasma -
My Audiosource AMP300 arrived today. 1st impression is WOW this thing is heavy (40+ LBS). Hooked it up in my 2 channel rig for a brief listen and...
:D:D
It does not seem to have the warmth of the harman/kardon 3480, but it drives the SDA's nicely. Great budget power amp.
Still, I like the 3480. Hard to describe, but it just sounds "good" to me. Never heard tubes, but one pro reviewer said the 3480 had a "tube like" sound. One day I'll try to get some of those silly tubes.:)
I'll put the AMP300 into my H/T soon as a filler until I can get a higher end power amp.
For all of you polkies on a strict budget like me (WIFE and 4 kids) the AMP300 is a nice solution to power your Polks and take a load off of your AVR. -
Not to mention they do very well as monoblocks. There's no shortage of power in the transformer and the output stages are rock solid.
Both the amp 200 and the amp 300 are very well built amps using toroidal supply transformers and hefty heatsinks.
I have used many of them for myself and setting up for family and friends without any failures except for one led failure on a friends 300...didnt affect the amp whatsoever but he called audiosource and they sent him out the led assy as well as the little circuit board that controls which color led is active ( Blue or red...normal operation ...sleep...fault ) for zero charge no questions asked.
They also drive low impedances very well...they are advertised as 2 ohm stable and they truely are...I actually have one of my own amp300's driving one of my TC Sounds TC2K subwoofer drivers that is a 4 ohm voice coil and I have the amp300 bridged for that single subwoofer ( Short version...Each channel basically seeing a 2 ohm load ) and it works fantastic.The first rule of Fight Club is you don't talk about Fight Club -
I've been using 2 Audiosource Amp Three's (predecessor to the 300) mono-bridged for my LS90's for a few years now.
They were a major improvement over a Pioneer Elite 45TX so much more dynamic. I've toyed with replacing them several times, but I just really do not have any complaints with their performance, other than needing to lift the ground to eliminate some hum.
The other feature I find indispensable (and rare on amps in general) is the independent A/B speaker switching, which is operational even when running mono-bridged. I select "A" on each amp for the LS90's, and "B" to run speakers to remote rooms/locations through a Niles speaker selector. I don't run "A" and "B" simultaneously though, as that would likely put too much stress on the amps.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
Please explain the ground hum.
Seems I did notice a very, very small amount of hum with the volume all the way down.
Thanks! -
I have a pair of AmpOne A's and there is no hum for me. I've had them on top of speakers, on wooden floors, sideways, you name it.
Even the noise is excellent. I never tried with muting plugs, but the hiss is only audible to me if my ear is less than 2" from the tweeter, with no source attached. My speakers are also 92dB/W/m.
My only complaint is that they have different idle currents. With them side by side, no source attached, one stays warmer than the other. Had them hooked up as monoblocks and switching sides followed the amp. So now I have one that I prefer over the other; the warmer one. -
I have a One A also, and it doesn't have the hum that the Three's did - could be related to the fact that the One A only has a 2-prong plug.
Anyway, for the Three's, I "modified" some Volex power cords to lift the ground (think Dremel amputation). I liked this better than using a cheater plug.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
Conradicles wrote: »Please explain the ground hum.
Does using an aftermarket high end power cord help with this? -
Conradicles wrote: »Does using an aftermarket high end power cord help with this?
Possibly, maybe...
However, the 1st thing I would try is a cheater plug to lift the ground.
The other thing you could try is to reduce the input level control on the amp a bit.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
Possibly, maybe...
Thanks a bunch. I'll give that a try.:) -
This worked bro. Thanks!;)
The build quality of this amp is fantastic for a budget unit. Even the binding post terminals the back are higher quality than most AVR's.
Adding this AMP300 to my surround system made a noticeable difference in sound quality for the better. Seems like the SDA's sound fuller and the bass is better. Now my Pioneer only has to drive the center and surrounds.:D
