LSi 9 Mounting Options
Murray1
Murray1 Posts: 193
edited February 2009 in Speakers
Ok all you LSi 9 users, how have you found the best way to mount your speakers. Stands and sticky putty just don't seem very appealing and wall mounts appear to locate speakers too close to the wall. I am leaning to the 15's because mounting seems to be a real hassle. We have a 46" wall mounted tv and have yet to purchase a media table for electronics. Wondering if there is a table that could also handle 9's and meet suggested placement locations(i.e. 9' separation/1'-2' from wall/tweeters at ear level). Thanks all.......
Post edited by Murray1 on
  • AndyGwis
    AndyGwis Posts: 3,655
    I have some 24" stands and really like them. The speakers are so heavy that I don't even have them tacked down or anything. They sit very sturdy, but I guess if I had kids or pets I'd look into a different solution.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • PSOVLSK
    PSOVLSK Posts: 5,372
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-804
    Admittedly, I've only been using these for a couple of weeks, but I'm happy with them. Like Andy, I just have my 9's on the stands with no putty, etc. I think they would have to get hit pretty hard to knock them off of the stands. I do have two kids, but the stands are in a dedicated HT, not just in the living room where there is more activity.
  • Murray1
    Murray1 Posts: 193
    Thanks guys for the info. Any idea what the dimensions are of the stand top where the speaker sits. Seems like most stands are around 6"x6". Sure would like to hear from someone who is using the 9's without stands. Just can not imagine the wife liking the "stand look".
    treitz3 Posts: 19,952
    Murray1 wrote: »
    Personally, I prefer to mount women but hey.......whatever floats your boat dude. :eek:
    What kind of flooring do you have? If it's carpet, velcro will work to keep your speakers on a speaker stand and if you have hardwood floors velcro would work just the same to couple it to the floor if you don't use the spikes. If you have carpet, you can drill three or four holes through the bottom of a speaker stand and literally drill the speaker stand to the flooring [provided you are not on concrete below the carpet] and cover up the screws with whatever matches the substrate of the base of the speaker stand.
    You have options, we just need to know a little bit more about your situation.
