Need help with a hum
chargerman426
I have an Integra 9.8 and a Sunfire 400x7. Well the problem is whenever I turn on my X Box 360 I get this bad hum through my speakers. What can I do?
If life had more tubes it would be a lot smoother.
Post edited by chargerman426 on
Use a cheaper plug on the Xbox to lift the ground.Political Correctness'.........defined
President of Club Polk -
I use a tos link cable to the pre and component cables.
The xbox uses proprietary power cable with no ground.If life had more tubes it would be a lot smoother. -
Go HDMI over the Xbox if you can, best investment I ever made. Yeah ground lift should help with hum. Check cables and make sure all are fully seated.Shoot the jumper.....................BALLIN.............!!!!!
My X box doesn't have HDMI.If life had more tubes it would be a lot smoother.
