RTi A5 EQ settings
I just got my refurb RTi A5's today. First off, I had forgotten what midrange sounded like until I hooked these up. Really suprised by the bass these put out. I almost can't hear my sub at all now.
That's all I'm getting though, voices are not near as loud as everything else. I've been messing with my receiver and can't seem to get my highs, as loud as everything else.
I have a denon 1909 reciever, and no external amp. I ran the audyssey setup, and messed with the EQ.
I have my speaker wires hooked into the top posts(I don't know if that makes any difference, these are the first speakers I have had that I could wire more than 1 way.)
I've heard alot of people say that these speakers are bright, and I don't hear that at all. I would actually like to brighten them up some, any suggestions would be appreciated.
I have them set to small, with the crossover at 80.
I can't think of any other info to give.
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Post edited by bevo on
I would play around with the setting and make sure you read the manual on the Denon. I had the 1508 & 1708 and noticed the center channel didn't sound as crisp as the fronts so I exchanged it with another one. Same results as before.
What do you mean by "messed with the EQ"?
Some avr brands have different defaults for their autocalibrations for audio.
For example, Yamaha has YPAO - similar to Audessey - and the 'default' if you do not change any settings when doing an auto calibration, is what they call "Natural" -which deamphasizes high frequencies and tends to 'average out' all the frequencies detected. Recommended if highs tend to sound bright.
This is what I run as it works well in my set up and 'tames' the brightness which the RTiA series can be branded.
If you think that your RTiA5s sound dull - check your manual for what the 'default' Parametric EQ mode is.
Your Denon should have a mode where you can defeat or turn off any PEQ or GEQ (graphic EQ) - try that and see if it restores the high end of your RTiA5s.
You may also want to experiment with other Audessey PEQ modes offered in the Denon to see if that provides a better match for the RTiA5 and your listening tastes.
Regards,
Erik
Thanks for the advice. I finally figured out how to actually use my own EQ settings. The menus on the denon for adjusting the EQ, and activating the custom EQ are in different places. It's like they hid actually being able to turn it on, so you would use the audessey settings.
The speakers sound great now, actually better then I thought. The bass is what really surprised me. I almost can't even hear my sub anymore. Looks like that will be my next upgrade. The psw 111 just doesn't cut it with these speakers. I think I'm going to try and find a psw 505 for a good price.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Buttkicker(don't use or need it anymore since getting the Ultra) -
Nice to hear you have your A5,s working good. I bought a pair a couple of months ago (new) and they seem to sound better every day. Most guys in here recommend the 505 sub as a good value priced sub. I just bought a PSW125 on sale and have been pleasently surprised at its performance. I noticed a marked improvement with HT and two channel listening,with the sub addition. I don't find that my A5's pump much base but they may not be fully burned in,or whatever the proper term is."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic
