Question about recievers
dbs228
I think I have narrowed it down to two receivers Yamaha RX-V663BL and the onkyo 606. Anyone have any thoughts?
Post edited by dbs228 on
Step up to a 706 at least so you get preamp outputs in case you'd like to add an external amp later.Shoot the jumper.....................BALLIN.............!!!!!
Do you think the Yamaha would be a better choice? Do you possibly know if the Yamaha has preamp outputs. -
Yes, the Yammy has pre-outs.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »Yes, the Yammy has pre-outs.
Ok thanks
