This is what happens when...
Serendipity
Serendipity Posts: 6,975
edited February 2009 in Custom Fabrication
you forget to tighten some bolts ;)
http://www.youtube.com/watch?v=9fwVpNS41CY
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • Face
    Face Posts: 14,340
    edited February 2008
    He should slap his welder upside the head.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    That happened to a guy I knew in highschool that had a Vega all tubbed out that was literally thrown together.
  • Serendipity
    Dumb question, but what exactly happened? At first I was under the impression that something wasn't tightened properly, but then after reading Face's post I think it was a welding mistake???
  • RuSsMaN
    A tubbed car with what appears to be a stock leaf spring suspension (and the torque to break clean)? That pretty much says it all, no? Bound to happen, not a matter of if, but when.
  • Serendipity
    So if I understand correctly, it was a combination of a bad suspension and too much horsepower/torque?
  • clubvikram
    clubvikram Posts: 27
    edited April 2008
    yeah real bad suspension and excessive HP
  • Kinetic
    Kinetic Posts: 437
    edited April 2008
    i couldnt see the video, youtube take it off
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
  • zingo
    zingo Posts: 11,258
    edited April 2008
    Kinetic wrote: »
    I just got this too. What kind of video was this?!?
    treitz3 Posts: 20,131
    edited April 2008
    "Use violation"? WTF? It was a vid of a car who was taking off at a dragstrip and the bottom fell out from under it at takeoff.
  • Serendipity
    edited April 2008
    zingo wrote: »
    Like Treitz said, it was a video of a car taking off at a dragstrip and the rear axle (along with the wheels) fell off the car.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    reported
    Ben
  • Speedster
    Speedster Posts: 1
    edited August 2008
    Where is the Video
  • Face
    Face Posts: 14,340
    edited August 2008
    Kinetic wrote: »
    Speedster wrote: »
    Where is the Video
  • avhomedesigns
    avhomedesigns Posts: 29
