Speaker stands for LSiFX
mekatoka
Hello,
I rent a house and so cannot really mount the LSiFX's on the wall. What options do I have for speaker stands?
The problem is that the LSiFX's do not have any screws etc at the bottoms. Any suggestions are greatly appreciated
Post edited by mekatoka on
Believe rears need to be above head level which means some fairly tall stands. I have been researching some of the treads regarding stands and brackets for future LSi 9's. Since mine are for the fronts, tweeters need to be about ear level. Believe that has me into 32-26" stands. Some of the posts I have read mention a blue putty like material that people are using to hold their speakers to stands. Search some of the threads and you will see what I am talking about. Also threads on speaker placement which should also help. Good luck.
Thanks for the reply Murray1. I dont really like that idea but I guess there is no other option then.
I was hoping to find some kind of a stand that would have a base and then an extension that would screw into the back of the LsiFX but I guess I am asking for too much:( -
Sounds like stands are your only option. Since you already have your speakers, get a couple of friends to hold them at different heights to see how they sound and what height stand you need. Good luck again......
Bought Lovan Affiniti 38" Stands in Piano Black to match the piano black on LSiFX. Bought them at www.standsandmounts.com. Lovans were also sold in Amazon but they didn't have 38".
