I've got a new turntable!!
schwarcw
Before everyone get's excited, it's not a grand purchase. I bought it for $200 and got $60 back from Microsoft into my Paypal account (and yes I did get my money). It's a Yamaha YB-800 (pic below).
The table is in remarkable condition. Heavy Lexan cover with no scratches, no marks on the plinths , direct drive, strobe control works perfectly and holds the speed. It came with s Shure M91E cartridge, with a brand new replacement stylus. I have a couple of adjustments to make. First the bottom of the cartridge drags ever so lightly on the record. The tonearm raises and lowers easy enough with a thumb screw. How do I set the properer VTA on this machine?
Second, I need a new platter mat. The original rubber mat with the serrated grooves is in excellent shape, but I'm looking to replace it with an "inexpensive' mat. I've thought about the cork mats, carbon graphite mats, Music Hall ring mats, Audioquest gel mat, etc. I don't want to spend more than $150. Hell, I didn't pay that much for the TT.
Any recommendations on VTA adjustment and mats?
Carl
Post edited by schwarcw on
Coolness. Enjoy.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Congrats Carl,, enjoy. :)It's just starting.;)JC approves....he told me so. (F-1 nut)
Hi Carl! Very nice. Check Herbie's Way Excellent mats.
http://herbiesaudiolab.home.att.net/ttmat.htm
Various thickness, pick one to match your old mat, priced from $59 to $165. They even have a Micro-Spacer donut (mat diameter, .005" thick) for $5. All his products are covered by the 90-day no-risk trial.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
George, Carl was already there with a fine Marantz 6300 DD table in his garage system. Part of a fine retro all Marantz system. We spun some vinyl before heading to PF together. (He just has to get a TT into the house system).;)Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
woohoo, nice going Carl!I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Carl, the Vinyl Engine lists a YP-800, no YB? I checked the YP-800 manual and saw no mention of VTA adjustment. Something bent? Incorrect mat? Just grab the headshell and :eek:...never mind.:D
You need to have an account to DL files there, or I can email it to you.
http://www.vinylengine.com/library/yamaha/yp-800.shtmlSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Congrats on the new table!! Very nice looking. As a rule of thumb to get the VTA "roughed in" raise (or lower) the whole arm until the cartridge is parallel to the record (same distance off the record surface front and back). This is usually where most cartridge manufacturers recommend vta be set. As for mats, if your place is dry I'd look at an anti-static style mat. Enjoy.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Congrats Carl,
I never saw that table before. Looks nice. For the price you probably can't do better!! Let us know if you get that nice "black" background. Man, you get some deals!! -
Congrats on the vintage new table Carl. I like those little black shims on it . . . .:D
Carl's not new to vinyl by any means.
Congrats Carl. Very nice looking.
That's in pretty good shape. Nice score Carl.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Nice Carl - congrats. Good luck on all the upgrades.Michael
NORTH of 60° -
Thanks for all the well wishes. I ordered a mat from Herbie's Audio Lab today because I want to use Joe's clamp. I was shopping for a Denon PL-160. Buy.com had the for $103:eek: but they were sold out. I'm going to wait to see if it comes in. The Lexan cover weighs a ton. Overall the unit weighs about 27 lbs. It has a leveling bubble build into the metal plinth. The tonearm was made by Micro Seiki (242 mm). The whole arm/mass compliance thing has my head spinning. As does the VTA adjustment. I may get the unit rewired with some RCA jacks on the back to take advantage or trying different cables. I've got a 2 meter pair of Cardas Quadlinks that are ready to go.
I need to get a phono pre. I'm thinking one of those little battery operated Hagerman units like Analog97 has.
More to come!:)Carl -
Nice table.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
....Speakers: SDA-1C (most all the goodies)
Joe's clamp is remarkable. If you want to use that then you might not need Herbie's mat. I have tried that combo on Music Hall MMF5 and it didn't work, individually they work very nice and you will get more mileage out of clamp then the mat.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
Congrats and enjoy the new TT. Let us know how it sounds.
That's an early Yamaha tt; not a model that I've ever seen before.
mhardy6647 wrote: »That's an early Yamaha tt; not a model that I've ever seen before.
Mark, there is a fair amount of info on this table on vinylengine.com. It was a mid to late '70's vintage, sold for about $500. It wasn't top of the line more of a midfi product. Great build quality. I ordered a Herbie's Audio mat, a cartridge is in the works and maybe get some RCA connectors on the back.Carl -
What cart did you decide to buy Carl?
Hi Joe!
Buy.com has the Denon PL-160 on sale for $103 and free shipping. Unfortuneately the cartridge is on backorder, so I'll wait few week to see what happens. Most retailers want $155 - $179 for this cart. It's a high output MC so I won't have to use a step up transformer. I'll need to use one of my tube amps as a pre until a gt a Hagerman or another phono pre. I'm cutting back on my audio budget as I don't want to sink too much money into this economy. I'm betting on the Socialist policies to fail.Carl -
WAAAAAAAAAAAAAAAAAAAAA you are too funny Carl. -
Well, that's kind of paradoxical if you ask me. Stock up on hifi gear; later you can barter for food! :-)I'm cutting back on my audio budget as I don't want to sink too much money into this economy. I'm betting on the Socialist policies to fail. -
wise thinking Carl. Dow Jones Index went back to 2002. I used to wish to wind the time back to college time fun, but instead my portfolio that went back 6 years value. crazy time.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Nice TT Carl._________________________________________________
Hello
I was wondering also, what cart your going to get for it. I posted in another thread about input on a cartridge I'm thinking about getting but didn't get any response......
http://www.amazon.com/Denon-DL160-Output-Moving-Cartridge/dp/B000I21PWW
I have a Pioneer PL 510A that I'm putting it on.Testing
Testing
Testing -
The PL-160 is a very good high output MC cart. But $175 is a little steep. Buy.com had these for $103 with free shipment.Carl
Had, is the word of the day....
http://www.buy.com/prod/high-output-moving-coil-cartr/q/loc/111/208156821.html
Well, hopefully they'll get some more in....
I went ahead and ordered one anyway.
AND, I need to start reading ALL the posts, geez.....Testing
Testing
Testing
