I've got a new turntable!!
schwarcw
schwarcw Posts: 7,358
edited February 2009 in 2 Channel Audio
Before everyone get's excited, it's not a grand purchase. I bought it for $200 and got $60 back from Microsoft into my Paypal account (and yes I did get my money). It's a Yamaha YB-800 (pic below).
The table is in remarkable condition. Heavy Lexan cover with no scratches, no marks on the plinths , direct drive, strobe control works perfectly and holds the speed. It came with s Shure M91E cartridge, with a brand new replacement stylus. I have a couple of adjustments to make. First the bottom of the cartridge drags ever so lightly on the record. The tonearm raises and lowers easy enough with a thumb screw. How do I set the properer VTA on this machine?
Second, I need a new platter mat. The original rubber mat with the serrated grooves is in excellent shape, but I'm looking to replace it with an "inexpensive' mat. I've thought about the cork mats, carbon graphite mats, Music Hall ring mats, Audioquest gel mat, etc. I don't want to spend more than $150. Hell, I didn't pay that much for the TT.
Any recommendations on VTA adjustment and mats?
Carl
Post edited by schwarcw on
  • wingnut4772
    wingnut4772 Posts: 7,519
    Coolness. Enjoy.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • george daniel
    george daniel Posts: 12,096
    Congrats Carl,, enjoy. :)It's just starting.;)
    SCompRacer Posts: 9,121
    Hi Carl! Very nice. Check Herbie's Way Excellent mats.
    http://herbiesaudiolab.home.att.net/ttmat.htm
    Various thickness, pick one to match your old mat, priced from $59 to $165. They even have a Micro-Spacer donut (mat diameter, .005" thick) for $5. All his products are covered by the 90-day no-risk trial.
    George, Carl was already there with a fine Marantz 6300 DD table in his garage system. Part of a fine retro all Marantz system. We spun some vinyl before heading to PF together. (He just has to get a TT into the house system).;)
  • polkatese
    polkatese Posts: 6,767
    woohoo, nice going Carl!
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    Carl, the Vinyl Engine lists a YP-800, no YB? I checked the YP-800 manual and saw no mention of VTA adjustment. Something bent? Incorrect mat? Just grab the headshell and :eek:...never mind.:D
    You need to have an account to DL files there, or I can email it to you.
    http://www.vinylengine.com/library/yamaha/yp-800.shtml
  • Fongolio
    Fongolio Posts: 3,516
    Congrats on the new table!! Very nice looking. As a rule of thumb to get the VTA "roughed in" raise (or lower) the whole arm until the cartridge is parallel to the record (same distance off the record surface front and back). This is usually where most cartridge manufacturers recommend vta be set. As for mats, if your place is dry I'd look at an anti-static style mat. Enjoy.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • analog97
    analog97 Posts: 328
    Congrats Carl,
    I never saw that table before. Looks nice. For the price you probably can't do better!! Let us know if you get that nice "black" background. Man, you get some deals!!
  • hearingimpared
    hearingimpared Posts: 21,136
    Congrats on the vintage new table Carl. I like those little black shims on it . . . .:D
  • hearingimpared
    Carl's not new to vinyl by any means.
  • Fireman32
    Fireman32 Posts: 4,845
    Congrats Carl. Very nice looking.
    treitz3 Posts: 20,076
    That's in pretty good shape. Nice score Carl.
  • janmike
    janmike Posts: 6,146
    Nice Carl - congrats. Good luck on all the upgrades.
    Michael ;)
    NORTH of 60°
  • schwarcw
    Thanks for all the well wishes. I ordered a mat from Herbie's Audio Lab today because I want to use Joe's clamp. I was shopping for a Denon PL-160. Buy.com had the for $103:eek: but they were sold out. I'm going to wait to see if it comes in. The Lexan cover weighs a ton. Overall the unit weighs about 27 lbs. It has a leveling bubble build into the metal plinth. The tonearm was made by Micro Seiki (242 mm). The whole arm/mass compliance thing has my head spinning. As does the VTA adjustment. I may get the unit rewired with some RCA jacks on the back to take advantage or trying different cables. I've got a 2 meter pair of Cardas Quadlinks that are ready to go.
    I need to get a phono pre. I'm thinking one of those little battery operated Hagerman units like Analog97 has.
    More to come!:)
    Carl
  • ESavinon
    ESavinon Posts: 3,067
    Nice table.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • thsmith
    thsmith Posts: 6,082
  • izafar
    izafar Posts: 819
    schwarcw wrote: »
    Joe's clamp is remarkable. If you want to use that then you might not need Herbie's mat. I have tried that combo on Music Hall MMF5 and it didn't work, individually they work very nice and you will get more mileage out of clamp then the mat.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • engtaz
    engtaz Posts: 7,669
    Congrats
    engtaz
  • organ
    organ Posts: 4,969
    Congrats and enjoy the new TT. Let us know how it sounds.
    mhardy6647 Posts: 35,198
    That's an early Yamaha tt; not a model that I've ever seen before.
  • schwarcw
    Mark, there is a fair amount of info on this table on vinylengine.com. It was a mid to late '70's vintage, sold for about $500. It wasn't top of the line more of a midfi product. Great build quality. I ordered a Herbie's Audio mat, a cartridge is in the works and maybe get some RCA connectors on the back.
    Carl
  • hearingimpared
    What cart did you decide to buy Carl?
  • schwarcw
    Hi Joe!
    Buy.com has the Denon PL-160 on sale for $103 and free shipping. Unfortuneately the cartridge is on backorder, so I'll wait few week to see what happens. Most retailers want $155 - $179 for this cart. It's a high output MC so I won't have to use a step up transformer. I'll need to use one of my tube amps as a pre until a gt a Hagerman or another phono pre. I'm cutting back on my audio budget as I don't want to sink too much money into this economy. I'm betting on the Socialist policies to fail.
    Carl
  • hearingimpared
    schwarcw wrote: »
    WAAAAAAAAAAAAAAAAAAAAA you are too funny Carl.
    schwarcw wrote: »
    Well, that's kind of paradoxical if you ask me. Stock up on hifi gear; later you can barter for food! :-)
  • polkatese
    wise thinking Carl. Dow Jones Index went back to 2002. I used to wish to wind the time back to college time fun, but instead my portfolio that went back 6 years value. crazy time.
  • Ricardo
    Ricardo Posts: 10,634
    Nice TT Carl.
    SOPA
  • Systems
    Systems Posts: 14,872
    Hello
    I was wondering also, what cart your going to get for it. I posted in another thread about input on a cartridge I'm thinking about getting but didn't get any response......
    http://www.amazon.com/Denon-DL160-Output-Moving-Cartridge/dp/B000I21PWW
    I have a Pioneer PL 510A that I'm putting it on.
    Testing
    Testing
    Testing
  • schwarcw
    The PL-160 is a very good high output MC cart. But $175 is a little steep. Buy.com had these for $103 with free shipment.
    Carl
  • Systems
    schwarcw wrote: »
    Had, is the word of the day....
    http://www.buy.com/prod/high-output-moving-coil-cartr/q/loc/111/208156821.html
    Well, hopefully they'll get some more in....
    I went ahead and ordered one anyway.
    AND, I need to start reading ALL the posts, geez.....
    Testing
    Testing
    Testing
