PSW505 or DSW mp 3000
smoke3
Im thinking of upgrading my PSW 505 to a DSW micro pro 3000 is the expense
worth the upgrade? Im currently running all LSI speakers. Just looking for some tighter bass. Any opinion's
Post edited by smoke3 on
Yes it's worth the upgrade depending on how much you pay for it.
http://www.warehousedeals.com/Polk-Audio-DSW-MicroPRO-4000-Subwoofer/M/B0016GPDS6.htm
I have not seen any authorised online dealer with lesster price.
i myself am looking at a good deal on MP1000 for a better price. i would love to take the big fellow but i cant carry this back home when i finish my work in the US, good luck on your hunt for the MP4000, hope the link above works out for you. IF yes let us know about your listening results.:D -
For 250 more the mp 4000 does sound like the wiser way to go.Just not convinced the bass is that much better than the 505.still need more info from someone that has one. Thanks for the info so far Please keep it coming
I have a PSW505 and it's the best sub I've ever owned and I have plenty to compare it to. It's precise and will also hit hard enough to rattle not only your couch but also your whole house. I'm sure the micropro is awesome and sounds great and loud but depending on your room situation you could get the same or similar result with the 505 at 1/5 the price.
