Copper Lined Avel Box
MillerLiteScott
MillerLiteScott Posts: 2,564
edited February 2009 in DIY, Mods & Tweaks
The past two weeks my roofers have been putting a cedar shake roof on the house I am building for a client. As promised I scarfed up a few copper scraps and lined my DIY Avel isolation transformer enclosure for my AI-1 interconnect.
I have not had a chance to listen to see if there were any improvements but here are a few pictures.
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
  • hearingimpared
    hearingimpared Posts: 21,136
    Nice job Scott, you're hired.
  • dorokusai
    dorokusai Posts: 25,576
    That's tight.
  • nikolas812
    nikolas812 Posts: 2,915
    Looks cool if nothing else...
    Nick
  • george daniel
    george daniel Posts: 12,096
    Nice work Scott,, very nice indeed.
  • Face
    Face Posts: 14,340
    Purdy!
  • schwarcw
    schwarcw Posts: 7,358
    The DIY A1-1 interconnect has come a long way!
    Carl
    F1nut Posts: 51,869
    Me like. :)
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Ok...newb question here.
    I've seen mention of these before...though I'm not sure what they are exactly.
    I assume that they're an upgraded SDA IC?
    How does the toroid come into play? Or is that even a toroid? Is this something that goes inside of the speaker? I assume it's external since you finished the cabinet on it so nicely.
    Looks like quality work either way though, nice job.:)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • george daniel
    it's a AI-1 "dreadnought" that is used for non common ground amplification with SDA's. And perform well,they do.:)
  • comfortablycurt
    Ahh...I see. Thanks for clearing that up for me George and Sal.:)
    I may be looking into this myself eventually when I get some SDA's of my own. Unfortunately that's probably still a 2-3 years down the road though. I'll get there eventually.:)
  • MillerLiteScott
    Thanks guys.
    I was very easy to do and took me about 45 minutes even with my 4 year old helper. The copper sheets I used are 20 oz. copper which is probably twice as thick as the aluminum sheeting I was using before. I believe the properties and thickness of this copper should offer quite a bit more shielding over the aluminum.
    I did listen to a bit of music last night and I do not know if it made any improvement over my previous aluminum shielding but it did sound pretty good last night until my Valentine came down to the basement.:D
    Scott
  • unc2701
    unc2701 Posts: 3,587
    Probably work better if you attached the copper to ground.
    Backburner:Krell KAV-300i
  • hearingimpared
    Lasareath wrote: »
    One day I will make one like DK made. Right now I don't even own Mono Blocks.
    That type of situation never stopped you before.;)
  • ShinAce
    ShinAce Posts: 1,194
    unc2701 wrote: »
    Ditto.
  • MillerLiteScott
    ShinAce wrote: »
    Ditto.
    Why? If I am shielding from RF?
    Scott
  • unc2701
    Scott
    Good point, but lower frequencies are probably more of an issue for your application & your cage will be more effective on them when grounded.
  • ShinAce
    The toroid's field is internal, so that's good.
    The shield is shunting EMI and dissipating some energy as eddies. By connecting it to a ground, you're now excluding most and shunting some of the EMI to ground.
    I see it as a guaranteed good choice.
    p.s. Have you tried it yet? Do it!!!
  • MillerLiteScott
    I have not tried it. I assume I should connect both of my negative terminals to the copper shield? Correct?
    Scott
  • ShinAce
    Scott
    I'd ground it to the nearest case of a piece of equipment that has an earth ground connected to the case. But that's just me.
    If you have a piece of equipment with 3-prong outlets on the back, you could snip a cheap 3 prong cord and use that as a ground wire.
    Do not use the negative terminals, since the point of the transformer is for non-common ground amps(right?). It's not even worth researching, as it depends ultimately on your amp.
  • MillerLiteScott
    All of my 2 channel pieces have ground lugs on the back an I have them all tied together and connected to my Panamax ground lug on the back.
    Should I just run a ground wire from the copper shielding to the ground lug on my Panamax?
    Scott
  • unc2701
    That'll do it.
