FM boost?
dborzz
dborzz Posts: 87
edited February 2009 in Electronics
What do you guys recommend for boosting an FM signal, I am about 20 miles from Cleveland, OH and my reception is average at best. I would like to stay away from outdoor antennas, so anything not too expensive and indoors would be great! Thanks
Polk T90e's(m60)-mains
Polk CS2-center
Polk OWM3's-surrounds
Polk Micro Pro 1000-sub
PS3-blu-ray,gaming
Pioneer 43inch purevision plasma
Onkyo tx-sr606
MIT EXp 1
Post edited by dborzz on
  • fbm211
    fbm211 Posts: 1,488
    you could try one of those terk antennas that Ive seen in the parts express catalog. http://www.parts-express.com/wizards/searchResults.cfm?searchFilter=fm+antenna&FTR=&search_type=main&WebPage_ID=3&x=27&y=13
    Not sure if there any good.I never used one.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • LessisNevermore
    LessisNevermore Posts: 1,519
    Avoid passive antennas, as I've never found one that did a very good job. Amplified is what you want, one that uses electricity. The rabbit ear design will probably get you better directionality, at the expense of looks.
  • steveinaz
    steveinaz Posts: 19,545
    What about an outdoor antenna mounted in your attic?
  • dborzz
    dborzz Posts: 87
    I have an outdoor antenna and it is an absolute eyesore on the roof.....I would take it down but I have a very high roof and it sure looks slippery up there in the middle of winter. Plus there is no longer any wire running from it so.....oh well on that. I guess I just want something small and indoor that will help out some. Thanks so far for your help fellas!!
    Polk CS2-center
    PS3-blu-ray,gaming
    Onkyo tx-sr606
    MIT EXp 1
  • dborzz
    dborzz Posts: 87
    Ohhh....you said in the attic steveinaz. Hmmm...didn't realize you could do that. I suppose that's something I can kick around, don't wanna spend alot of coin on it because I don't listen to the radio all that much honestly, but when I do it would be nice not to hear all that static...lol
    Polk CS2-center
    PS3-blu-ray,gaming
    Onkyo tx-sr606
    MIT EXp 1
  • Marty913
    Marty913 Posts: 760
    The Terk works better than the dipole-wire-type that usually comes with a receiver / tuner but not by a lot. I have one and it clears up the close-by stations a little and looks better but that's about it. Not a whole lot better than rabbit ears. Amplified is better for distance. Attic-Mounted is is way better, doesn't have to be amplified normally but you do have to run wires. That and you said you don't listen to radio very much. Most of my radio listening now is Internet radio so I only used the Terk occasionally.
    I guess everybody's right on this one. Depends on how much trouble / money you want to invest.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • dborzz
    dborzz Posts: 87
    the less trouble and less money I can get away with the better, but I guess I shouldn't expect much huh? Oh well, thought I'd ask anyway. thanks
    Polk CS2-center
    PS3-blu-ray,gaming
    Onkyo tx-sr606
    MIT EXp 1
  • dudeinaroom
    dudeinaroom Posts: 3,609
    you could by a tv signal booster. I have one hooked up Form ant. to splitter to tv, and receiver. The on I have has a 25 db gain. I pull stations in from all over ( up to 3 hours away).Before I could only pick up 5 or six stations now I have way more than I can preset( almost every other station on the dial comes in.) The one I am using Is from Home depot, and has an fm trap switch(which is off). I think I paid $25 for it. I also have one with 10 db of gain and works almost as well, I think I paid around $12 for it at walmart. good luck.
  • Phil Dawson
    Phil Dawson Posts: 288
    I live way out in the sticks. 20 miles to the closest town and 25 miles to the next one with a mountain range in between (Montana). I put an FM antenna in the attic of my garage (we have winds up to 100mph here) and it works great. It seems like the cost was about $50.00 plus co-ax. I get between 15 and 20 stations. I can get the make and model of the antenna if you wish.
    Good luck, Phil
    SRA-SDS Front
    2 cs400i Center
    SRS-SDA Rear
    Shure 12in sub
    B&K ref 10 pre-pro upgr to ref 50
    Techniques 1200 TT
    Mac MR71 Tuna
    Lexicon rt-20 uni player
    HK citation pre for TT
    2 PSE Studio Mono Blocks
    4 PSE Studio Stereo Amps
    1 Mac 2100 Amp for sub
  • dborzz
    dborzz Posts: 87
    Hey Phil thanks for the reply, I would appreciate the make and model to give me a better idea of what I may need. Thanks again
    Polk CS2-center
    PS3-blu-ray,gaming
    Onkyo tx-sr606
    MIT EXp 1
  • Phil Dawson
    The antenna is an Antenna Craft FM SS. It is a dipole style that comes folded up but extends out 3-4 feet in 4 directions. I got mine up into the attic space of my garage through a smallish access hole without any problems. It mounts with a bracket and I think it was a couple of screws into the wood. It is omni- directional so you don't have to adjust it. My cost was $45.00 form a place in Denver. I can get you that information too. Intrinsic Sound - great guys to deal with. By the way this antenna is passive so you don't have to mess with power. It works great. I can only get a few stations very weakly with a ribbon dipole and this gives me all of the stations in the area that I could hope to get.
    Good Luck, Phil
    SRA-SDS Front
    2 cs400i Center
    SRS-SDA Rear
    Shure 12in sub
    Techniques 1200 TT
    Mac MR71 Tuna
  • dborzz
    dborzz Posts: 87
    The funny thing is I have that exact same attic over the garage with a drop down ladder to climb into!! Sounds like a pretty simple solution and it is certainly better than going up on my rooftop which is way too high for my liking. Was hoping the strong winds that whipped through here last night would of ripped my old antenna off for me but oh well.
    Polk CS2-center
    PS3-blu-ray,gaming
    Onkyo tx-sr606
    MIT EXp 1
  • Mike Reeter
    Mike Reeter Posts: 4,315
    I've been thinking about one of these http://www.audiogon.com/cgi-bin/cls.pl?misctunr&1237673622&/Godar-fm1a-fm-antenna-gene-rub
    States it will pick up signals up to 150 miles
  • bikezappa
    bikezappa Posts: 2,463
    dborzz
    Get the $10 rabbit ears and move them around for best sound.
    RF amplifiers will not reduce the noise. Sorry.
