Need wedding car decorating ideas
66chevyIISS
66chevyIISS Posts: 857
edited February 2009 in The Clubhouse
Looking for some more ideas on what to do to my buddies car who is getting married on Saturday.
They will be leaving in there own car which is an 06 Honda Accord. Looking for some ideas on what to do outside the normal "tie some cans on it and write on the windows".
I plan on wrapping the car/doors with saran wrap, but looking for more!
Any tips would be great.
My Home Theater (WIP):
Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
Receiver: Denon AVR-1905
Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
Dual Subs: PSW202, and behind the couch Denon 8"
My showcase link:
Media Room pics
Post edited by 66chevyIISS on
  • Willow
    Willow Posts: 11,258
    Impossible to drive away
    Jack up the car, put blocks under the axle, then lower the car onto the blocks. When the newlyweds try to make their getaway, watch them rev...and rev...and rev.
    Brake wired to the horn
    The best man at my friends wedding rigged the horn to sound every time the brake was pressed, they drove half way down the road until they realized what was going on and had to return to fix it.
    taken from :
    http://www.ojar.com/view_15468.htm
  • dudeinaroom
    dudeinaroom Posts: 3,609
    Willow wrote: »
    Brake wired to the horn.......
    Awesome
  • Willow
    I like that one as well. :D
  • goingganzo
    goingganzo Posts: 2,793
    spray frost on all the windows
  • edbert
    edbert Posts: 1,041
    You know those little whistle type things that make a whizzing type sound the harder you blow into it? If you wrap duct tape around them (sticky side out) and put it just inside the tail pipe so it takes up practically the whole thing, they will really wonder what is going on with the car and more than likely not find it. They are easy to get out as well.
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • CaligulaPolk
    CaligulaPolk Posts: 1,650
    I suggest OP to tie his
    to your friend's car rear end. Let it rattle!!
    I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
    My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
  • ben62670
    ben62670 Posts: 15,969
    I could not resist:o
    Ben
  • CaligulaPolk
    ben62670 wrote: »
    LOL Hilarious BEN
  • 66chevyIISS
    lol Great ideas, keep em coming! well.. some of them were great anyways! haha
    Luckily I own the same type of car. I got 3 days to figure out this horn trick. I'm loving it.
    My showcase link:
    Media Room pics
  • BrettT1
    BrettT1 Posts: 560
    I wouldn't drag any Polks behind it... I'd suggest dragging some Bose. :D
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    HONK IF YOU'RE HORNY !!!
    Well, you knew my idea was going to suck, so ..... I didn't dissapoint ! :o
