Max Resolution with component cables
DannyD
If I have my bluray player hooked up to my 1080p Plasma via component video cables, what is the max resolution I should be able to get on my tv?
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Post edited by DannyD on
Component can technically do 1080p, but there are few (if any) players that support it due to copy protection. So using Component you're limited to 720p or 1080i.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
also depends on what your tv can do...some won't display 1080p over componentTheater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
Bed Room: Panasonic TCP50x1, Samsung Bd c7500
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3 -
Get HDMI cables and be done with it. It takes care of audio and video. -
I need some help and I have researched and called numerious people and get mixed answers. I am looking at getting a amp that has 6 channels (4x 100 W @4ohms and the last two channels together are 250W @ 4 ohm for a sub)
I would like to hook up 4 polk audio speakers 60 W @ 4ohm's each, 4 factory speakers which are also 60W @4 ohm's each, and a sub 200 W @4ohm
Can I hook up the 4 factory speakers to 2 channels, the 4 polk audio speakers to 2 channels and use the last 2 channels to push the sub?
From what I understand if I hook up 2 4 ohm speakers to 1 channel is will half the Watt so in this case itwould push 50 watts to each 60 watt speaker...
Can someone give mesome guidance and advice on this?
This is for my boat... -
breaststroke56 wrote: »I need some help and I have researched and called numerious people and get mixed answers. I am looking at getting a amp that has 6 channels (4x 100 W @4ohms and the last two channels together are 250W @ 4 ohm for a sub)
I think that's one of the most blatant off-topic thread jacks I've ever seen...
My apologies to the OPSlowly emerging from the 90's
Fronts: Polk LSi15's
Center: Polk CS350ls
Pre: Sony STRDA555ES
Amp: Rotel RMB-1075
Sub: Velodyne SPL-1000
TV: 46" Sharp Aquos LCD
Dust magnet: Sony PS3 -
Breaststroke
That sounds like a bad idea to me. I think you would send that amp into protection mode before you leave the dock.
You may also get some better help in the Car audio section all the way at the bottom of the board.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
Back on topic...
As of a year or so ago there was no standard for 1080p over component. You'd need a device and TV that both did it and agreed on how it should be done. I've been meaning to try it w/ my oppo and samsung since allegedly they both can do it, but I don't have any non-copyrighted material to try it out on ...Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Xbox360 is suppose to do 1080P with comp cables but I know of no HDTV that will accept 1080P over compSpeakers: SDA-1C (most all the goodies)
Get an HDMI cable from Monoprice.com
Under $15 shipped and you have a better picture and full audio support. -
they're out there....samsung dlp's are oneTheater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
