Max Resolution with component cables
DannyD
DannyD Posts: 133
edited February 2009 in Electronics
If I have my bluray player hooked up to my 1080p Plasma via component video cables, what is the max resolution I should be able to get on my tv?
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Post edited by DannyD on
  • tcrossma
    tcrossma Posts: 1,301
    Component can technically do 1080p, but there are few (if any) players that support it due to copy protection. So using Component you're limited to 720p or 1080i.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • eclimax13
    eclimax13 Posts: 168
    also depends on what your tv can do...some won't display 1080p over component
    Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
    Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
    Bed Room: Panasonic TCP50x1, Samsung Bd c7500
    Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
  • leroyjr1
    leroyjr1 Posts: 8,785
    DannyD wrote: »
    Get HDMI cables and be done with it. It takes care of audio and video.
  • breaststroke56
    breaststroke56 Posts: 2
    I need some help and I have researched and called numerious people and get mixed answers. I am looking at getting a amp that has 6 channels (4x 100 W @4ohms and the last two channels together are 250W @ 4 ohm for a sub)
    I would like to hook up 4 polk audio speakers 60 W @ 4ohm's each, 4 factory speakers which are also 60W @4 ohm's each, and a sub 200 W @4ohm
    Can I hook up the 4 factory speakers to 2 channels, the 4 polk audio speakers to 2 channels and use the last 2 channels to push the sub?
    From what I understand if I hook up 2 4 ohm speakers to 1 channel is will half the Watt so in this case itwould push 50 watts to each 60 watt speaker...
    Can someone give mesome guidance and advice on this?
    This is for my boat...
  • timlitton
    timlitton Posts: 289
    I think that's one of the most blatant off-topic thread jacks I've ever seen...:confused:
    My apologies to the OP
    Slowly emerging from the 90's
    Fronts: Polk LSi15's
    Center: Polk CS350ls
    Pre: Sony STRDA555ES
    Amp: Rotel RMB-1075
    Sub: Velodyne SPL-1000
    TV: 46" Sharp Aquos LCD
    Dust magnet: Sony PS3
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    Breaststroke
    That sounds like a bad idea to me. I think you would send that amp into protection mode before you leave the dock.
    You may also get some better help in the Car audio section all the way at the bottom of the board.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • unc2701
    unc2701 Posts: 3,587
    Back on topic...
    As of a year or so ago there was no standard for 1080p over component. You'd need a device and TV that both did it and agreed on how it should be done. I've been meaning to try it w/ my oppo and samsung since allegedly they both can do it, but I don't have any non-copyrighted material to try it out on ...
    Backburner:Krell KAV-300i
  • thsmith
    thsmith Posts: 6,082
    Xbox360 is suppose to do 1080P with comp cables but I know of no HDTV that will accept 1080P over comp
  • Upstatemax
    Upstatemax Posts: 2,736
    Get an HDMI cable from Monoprice.com
    Under $15 shipped and you have a better picture and full audio support.
  • eclimax13
    thsmith wrote: »
    they're out there....samsung dlp's are one
