MIT cables IC's
Toolfan66
Toolfan66 Posts: 18,054
what end do i put to the receiver and what end to the amp?
Post edited by Toolfan66 on
    edited February 2009
    i have the MIT 2
  • comfortablycurt
    comfortablycurt Posts: 6,745
    I don't have any experience with MIT's, but the boxes go at the end of the signal path as far as I know. In your case, the boxes should be at the amp.
    Don't quote me on that though.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    F1nut Posts: 51,763
    The arrows indicate the signal direction. In your case, the arrows go towards the amp.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    Are there arrows inside the cables, so the signal doesn't lose it's way?:D:p
  • dorokusai
    dorokusai Posts: 25,576
    My MIT cables have a barely clothed, homeless man hustling my signal flow like a NYC 3 card monte dealer. I'm thinking of getting rid of him since he takes up so much room....and he's started urinating behind my rack.
  • phipiper10
    phipiper10 Posts: 961
    That's at least clearer that the tubes rule thread!
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
    if there was arrows,and/or directions to tell you how to put them on,then i would have not put up this thread.:rolleyes:
  • dorokusai
    The network boxes go with the signal flow....in your case, towards the amplifier.
  • metal83
    metal83 Posts: 1,219
    Keiko wrote: »
    Jesse, the AVt2 interconnects aren't marked to indicate direction. The long end is the source side though.
    These guys are all correct. I actually called MIT when i got my AVt-2 IC's and asked them this same question, because like you, i was unsure.
    Enjoy your MIT's! :D
  • hearingimpared
    hearingimpared Posts: 21,136
    There should be arrows on the sleeve that is at one end of the cable. Whichever direction the arrows are pointing, that is the signal flow. In other words the arrows should point away from the preamp and towards the amp. If for some reason there are no arrows then the end with the network boxes closest to them should go on the target side.
  • metal83
    TOOLFORLIFEFAN,
    Did you happen to grab any of the AVt-2 speaker cables that Greg was selling?
    Awesome, awesome cables! I've got my whole front stage wired with them, huge improvement over the 16ga walmart crap i had.
    metal83 wrote: »
    TOOLFORLIFEFAN,
    No i didn't, right now my whole front end is wired with Audioquest,i have the Diamondback IC's,and the Type 4 Speaker wire.they kick **** as well. this weekend i am going to put the MIT's in and give them time to break in,and see if i see an improvement. the price was right on the MIT's to give it a shot.
  • hearingimpared
    Keiko wrote: »
    I knew that Gus! You think I got the mentality of a Bigfoot? Goonie Goo Goo. :D
    Tell Lillian I said hi.
  • Face
    Face Posts: 14,340
    The lower MIT's do not have any arrows.
  • metal83
    Face wrote: »
    Yeah, the AVt-2 IC's have no arrows, but the AVt-2 speakers cables have the amp end conveniantly labeled.......wait for it.....wait.....AMP!! :p:D
