2 PolkSR124-dvc + 08 Kicker zx1000.1
Amit1591
hey im new at this site and just had a couple of questions. i recently just purchased 2 polk sr124-dvc's and was wondering if i can wire them both at 2ohm loads each to my one 08 kicker zx1000.1 amp resulting in a 1ohm load. Would it be possible, im new at this and wasn't quite sure. I know the parallel wiring is capable resulting in a 4ohm load but then my amp would only be pushing out 500 watts to both subs put together. I want it to be 2ohms each so both of the subs get 500watts each instead of only 250watts each.
Post edited by Amit1591 on
that will equal a 1-ohm load...question is if amp can handle it...Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
Get a 3rd sub and wire one in series and one in parallel? Haahaa I don't know if that would work, I'm no EE.
You can wire it to 1 ohm or 4 ohms. That amp doesn't like 1 ohm. Either you're going to have to run it at 4 ohm, or get a different amp or a pair of single 4's or dual 2's
-CodyMusic is like candy, you have to get rid of the rappers to enjoy it
