Which CDP?
I've heard the cambridge and it's a good player. But I prefered the Pioneer Elite PD-D9-J Super Audio CD player.
I think you can get it for less than a grand? Here's info from Pioneer:
PERFORMANCE FEATURES
AIR Studios Sound Tuning to ensure music is reproduced as near to the original as possible
Twin Wolfson® Digital to Analog Converters guarantee the most subtle music detail reproduction and delivers enhanced linearity, dynamic range and distortion-free response
Legato Link PRO ensures minimum phase shift across the entire audible frequency band
The SACD DSD Single-Chip Decoding in the PD-D9 reduces the digital circuitry signal path length, creating brilliant noise-free sound. An extremely stable, high performance Low-Jitter crystal oscillator circuit serves as a highly precise master clock for sound reproduction
Equipped with an aluminum front panel and an original professional readout mechanism with smooth loading
Pure Audio listening mode switches off the digital circuitry and display for a clean and detailed analogue sound reproduction
Finely selected high-grade parts in order to reproduce music in its purest form
TAOC Insulators provide added weight, stability and shielding for the ultimate sonic performance
Sampling Rate Converter for higher resolution digital processing
Twin Toroidal Transformers for higher resolution digital processing
Isolated Power Supply Blocks insure each section of the player has its own power source to be shielded from electromagnetic interferences
High Quality Pin Jack for the best possible connections with no signal loss
Professional Level Build Quality
Rigid Underbase Construction
Aluminum Side Panels and Top Plate
Rigid Laser Mechanism Cover
FORMATS
SACD, CD, CD-R, CD-RW, MP3 and WMA Playback
here is my choice....
http://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1237943693&/Marantz-SA-8001-sacd/cd-playerThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »
It's over rated."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
