Rotel and rtia9's
Neale13
Neale13 Posts: 88
edited March 2010 in 2 Channel Audio
Well I wanted more bass so I asked around here and was told more power and that would help my rtia9's.It sounds the same as it did with my rb-1080. I guess I need a subwoofer. I dont care what anybody says but my old cerwin vegas(vs-12) would rock the house with my old onkyo receiver. Im at a loss.Oh and alot of money. My pre amp,,rc-1070:(:(:(:(:(
Post edited by Neale13 on
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited March 2010
    If you want Disco sounding speakers I guess the CV are the way to go!! If you want a more true musical sounding speaker the Rotel/RTi9's combo is the way to go.
  • dkg999
    dkg999 Posts: 5,647
    edited March 2010
    If you really like the sound characteristics of your CV's, then you may be going down the wrong path. You will need sub-woofers to get close. Why not just get a pair of CV's for when you want to party, use the a9's when you want more accurate music reproduction?
    DKG999
  • Neale13
    Neale13 Posts: 88
    edited March 2010
    dkg999 wrote: »
    Does any one know of speakers that perform like the cerwin vegas but are better ?:confused:
  • dkg999
    dkg999 Posts: 5,647
    edited March 2010
    If you want loud party speakers then you probably need to look at commercial DJ/Sound type speakers. The other option might be some of the Klipsch line of speakers.
    DKG999
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited March 2010
    Are you speakers wired in phase with one another?
  • JPSmario
    JPSmario Posts: 142
    edited March 2010
    Maybe you should try some SDA's? I run an RB-980BX, a little more than half the power of your 1080, and my SDA 2A's produce way more punch and thumpage than I can use in this apartment:D If you keep your eyes open, you should be able to get a pair without too much of an investment. If they' don't do it for you, you should be able to move them on without much cost.
    Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
