speakers stands for FXi A6's?
bevo
bevo Posts: 306
edited February 2010 in Speakers
I just ordered a set of FXi A6's off of polk direct. I don't want to wall mount them, and the stands I use for my RM8's will never work. Any suggestions on some decently priced stands would really help me. I really don't want to spend much and would prefer them to be black.
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Post edited by bevo on
  • bevo
    bevo Posts: 306
    I've found all kinds of stands at one site and most are below what I expected to pay. The problem is the 6's are 14x9 and none of the stands top plates are close to that size Most of them are 7x7 the biggest I have found is 11x8. How much over hang can I have and the speaker still be fairly stable. I have a 4 year old boy and want to make sure they are not knocked over easy.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • dorokusai
    dorokusai Posts: 25,576
    Try Sanus as a brand and here for some options... www.racksandstands.com
  • bevo
    bevo Posts: 306
    I'm really wanting to order these stands before my speakers come next wednesday. What is the smallest top plate size I can use with the fxi a6's. The speakers are 13x9, I would really like some advice on this. I've never put bookshelves on stands before and have no idea how small the top plate can be.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • dorokusai
    The top plate should be close to the dimensions of the loudspeaker for safety. The rest is completely on you but I would recommend that as your guide.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    dorokusai wrote: »
    +1
    Especially with a speaker like the FXi's, which aren't square shaped. I'd imagine that could make them a little bit more unbalanced.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • bevo
    bevo Posts: 306
    I have looked and looked online and haven't been able to find a speaker stand that is close to the size of the speakers. Are there mounting holes in the bottom of the fxi a's?
    It looks like I might have to use 2 venter speaker stands.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • bevo
    bevo Posts: 306
    It looks like bose may be my only answer for this problem. http://www.crutchfield.com/p_018FS01/Bose-FS-01-Speaker-Stands.html?tp=1386&tab=detailed_info
    Who would have thought that bose would come to my rescue? These really are not big enough either but they may have to work, because I haven't been able to find anything else close to this size.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • Gulfstrings
    Gulfstrings Posts: 313
    Just measured the surface area on my FXi A6s. They could accommodate a stand pad of approximately 7" x 4.5" max, but I would want something a bit smaller so as not to be seen at the edges.
    How are speakers attached to their stands?
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Technics SL-1301/Shure M97xE
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    Antec VERIS A/V Cooler x 2
  • superjunior
    superjunior Posts: 1,632
    this would be a good diy project. I think it was sandworms that made some nice looking stands for the a6s and posted some pics. do a search, they're worth checking out
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • pioneercrazed
    pioneercrazed Posts: 37
    Here are the stands sandworms made, seem pretty simple.
    Being a triangle I think polk's dimensions are the max but the front is much thinner. Also you could attached them to the stand with something like velcro, etc... and weigh down the stand with something heavy like sand and many stands should work alright.
    http://www.polkaudio.com/forums/showthread.php?t=80993&highlight=stands
    http://www.polkaudio.com/forums/showthread.php?t=80226&highlight=stands
  • dorokusai
    Great link Pioneercrazed.
  • bevo
    bevo Posts: 306
    I'm just going to have to wait until they come to see what I'm dealing with. Being the odd shape that they are I hate to buy something now and be screwed when they get here because the stand won't work.
    As for building somethin for them, I really don't have the time. I have a store near me that sells over stocked furniture very cheap. I may just look for a couple small matching end tables. I could really use a couple with drawers in them anyway for the room. Someplace to put all of my extra wires would be nice.
    Thanks for the measurement gulf.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • dorokusai
    bevo wrote: »
    That sounds like a perfect solution Bevo...not everything has to be an official speaker stand. You could even add spikes to them as a secret modification....how cool would that be? :)
  • sandworms
    sandworms Posts: 1,043
    wasn't hard at all
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
