Center speaker for rt1000's
I recently purchased a pair of rt1000's. Polk rec the cs400i but are there any other current models that would work as well?
Thx
Thx
Post edited by QTS on
Find a cheap used CS350Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
CS1000p maybe?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Are there any models in the current line that work with the older rt1000's?
I would be okay finding older cs4xx or whatever but just in case I don't...? -
The CS400 would be your best bet honestly. The ones we mentioned will be cheaper, and have a matching tweeter..which is most important.Main Surround -
I agree it's better to have a matched center. I'll see what is avail on the net and go from there. Worst case if I run out of patience I'll look at other alternatives.
Thx.
