Unplugging receivers and TV's to save energy
charlie1978
It's been awhile since I have purchased a new receiver or TV (over 10 years) and I have a question that I can't find the answer to.
With all these new features can you unplug them from the wall for extended periods of time without loosing the settings. It seems they must have a internal battery that saves the settings like a computer does, but I do not know.
The reason is I have my house set up so that I can turn off the electric outlets to certain appliances when they are not in use, I am not home or on vacation to save energy.
Charlie
Charlie
Post edited by charlie1978 on
If you really want to save, just cut the main breaker when u go out.Shoot the jumper.....................BALLIN.............!!!!!
You have to leave the fridge, heaters and air cond set to min. of coarse I think he'd want to leave on though.Security lighting too..Most people just listen to music and watch movies. I EXPERIENCE them.
I've had power outages at my house and never had to re-do any setups on my TV or AVR.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|Nakamichi RX-202 Cassette
I save about 100 dollars a month now just by unplugging non essential electronics when not in use. If I didn't need the fridge I would probably cut the circuit breaker. I will ask onkyo directly.
No, your settings won't be lost. I unplug my Onkyo all the time.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Older equipment used super capacitors to save memory settings but those would only last a few hours. Some equipment used lithium batteries but those go dead as the equipment gets older. Most new stuff uses a form of nonvolitle memory called EEPROM (Electrically Erasable Programable Read Only Memory) or a similary type of memory called FLASH which is what those USB memory sticks use. Equipment using this type of memory should retain the settings for years without power.Dave
In love with SDA since 1984
2CH: SDA SRS (new caps) with NAD 541I, NAD 917 and modded Phase 400 (soon to be NAD 208)
HT: SDA 1C (new caps, SL2500s, bass mod) with NAD T763 and Monitor 4 as surround
Other vintage stuff, Sansui G9000, Pioneer 1980 -
My neighbor has a onkyo with not problems when the power goes out. The sony tv however loses its time and freaks out asking that you set it again. But that goes away after about 30 seconds.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
charlie1978 wrote: »I save about 100 dollars a month now just by unplugging non essential electronics when not in use. If I didn't need the fridge I would probably cut the circuit breaker. I will ask onkyo directly.
How many kilowatt hours per month do you allow yourself to enjoy your system?:rolleyes:
PatReceiver: Pioneer Elite SC-05
Amp: Emotiva Xpa-3
Front L/R: POLK Rti-a9s':D
Center:POLK Csi-a6
Rear surround's:POLK Rti-a1s'
Sub: Klipsch Synergy sub-12
Sony Kdl-46w4100 46" LCD
PS3
Audioquest type 4 wiring. -
Holy crap... my total bill doesn't even approach $100, and i leave all my stuff plugged in, all the time, and even leave my amp, tube buffer, and tv box powered up 24/7.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Holy crap... my total bill doesn't even approach $100, and i leave all my stuff plugged in, all the time, and even leave my amp, tube buffer, and tv box powered up 24/7.
You're lucky then. Here in NYC electric rates are insane!!
The key is to unplug stuff that gets warm when idle. For example, my sub amp gets hot to the touch if you put your hand on the plate amp.
I also used to run my HTPC 24/7 without power management (sleep/standby/hibernate) and it got hot as well. Now it's OFF unless necessary.polkaudio RT35 Bookshelves
Hrmm... yeah, that could be the difference. My electric bill is usually $60-$75 depending on whether. I leave the amp on because it sounds like crap for about 30 minutes after i figure power it up, so it's easier this way.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Hrmm... yeah, that could be the difference. My electric bill is usually $60-$75 depending on whether. I leave the amp on because it sounds like crap for about 30 minutes after i figure power it up, so it's easier this way.
Indianapolis, IN electric rates must be cheap then.polkaudio RT35 Bookshelves
I guess... i'll have to see what the rates are. That said, i'm in a large-ish 1 bedroom apartment with pretty modern construction. No sprawling 100 year old 2 story house here, so i probably save a lot on heating and air conditioning costs.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
The only time my electric bill is over $100 is when I use my central A/C in the summer, even then it's only $120-150 max. The last couple of months it's been around $75-85, and I leave just about everything plugged in."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
concealer404 wrote: »I guess... i'll have to see what the rates are. That said, i'm in a large-ish 1 bedroom apartment with pretty modern construction. No sprawling 100 year old 2 story house here, so i probably save a lot on heating and air conditioning costs.
60 year old house here, so the insulation and windows need to be updated. Will get to that soon.polkaudio RT35 Bookshelves
Yeah I live in an old DC apartment. I am sure most my bill is AC/Heat. I alos purchased one of those kill-o-watt things. It really does show you where the power is coming from. I didn't realize how much my receiver/DVD/and computer used just being on standby all day!
I think DC rates are kind of high also.
Good to know about the memory. Now I just need to try and fit the Tx-SR707 into my cabinet.... That thing is huge! -
Don't put it in a cabinet. Onkyos generate a lot of heat.polkaudio RT35 Bookshelves
charlie1978 wrote: »Yeah I live in an old DC apartment. I am sure most my bill is AC/Heat. I alos purchased one of those kill-o-watt things. It really does show you where the power is coming from. I didn't realize how much my receiver/DVD/and computer used just being on standby all day!
I got one of those kill-a-watt meters for Christmas and have measured a number of things around the house. With the exception of heating and cooling, the big ticket items were the computers. My entire office consiting of the computer, printer, LCD display, router, and modem if left running 24/7 costs about $115 per year to run - I only have it on about 4 hours a day. My apartment size refrigerator in the bar which seems like it is always running costs $20 a year to operate. My Musical Fidelity A1 which runs smokin hot 24/7 costs $36 per year to operate. I guess it all adds up.
I just bought a TX-SR707 yesterday to replace my Outlaw 1070 -
Damn....100.00 mo. X 12 mos. = a pretty good used amp and CD player
Now thats some motivation to save electricity.... -
Holy crap you save 100? I don't even spend that much. I have like 4 laptops, 3 desktops (most of which I have power savings off on) on all the time. This quad core laptop never shuts off, it just sits at the side of the bed when I want to randomly surf. Only time I ever go over 100 a month is like everyone else, with a/c in the summer, and then I hit about 150. 50 year old house with brand new insulation but old crappy windows.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
i picked up a kill-a-watt to see just how much power was wasted on things i wasn't using. rather than trying to unplug some things and waiting until my next electric bill, this thing helped me to directly single out the power-hungry appliances
where did you get the kill-a -watt thingy?
I have unplugged by Onkyo and Sharp TV without any issusesSharp Aqous 40" LCD
Onkyo TX SR-507 AVR
Onkyo DX-C390 CD Changer
POLK RTI8 Mains--Cherry
the rest...in process...slowly!! -
where did you get that killawatt thingy?Serendipity wrote: »Don't put it in a cabinet. Onkyos generate a lot of heat.
I was concerned with the heat "issuses" of onkyo when I got mine, however i have it in a cabinet and havent noticed any heat issues. I generally leave the front door cracked and good vents in the back. Ive run it for 6-8hours at a time with very little heat. But I also am not "working" it either.Sharp Aqous 40" LCD
Onkyo TX SR-507 AVR
sorry for the double post!Sharp Aqous 40" LCD
Onkyo TX SR-507 AVR
You guys are lucky with the $100 or less monthly power bills! I have a 2200 sq. ft house and if I see anything less than $350 a month I am happy.
I have a Sony DD processor that gets so hot I can't touch the top hardly. That thing has to be a waste of power! If heat equals wasted power.--Gary--
You can pick up the Kill A Watt from Amazon.com."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The small drains of multiple devices which stay on 24 hours a day is where you really waste money rather than the intermittant use high wattage items. Last year I started unplugging things not in use and the bill shows it, about 30% lower. For me its only maybe $25 per month but even still, thats $300 a year I was just pissing away and getting no enjoyment from. 10 years from now I'll be worth $3K more because of it.
thanks I'll check it out.
I would like to see the power usages from my stuff.
I have also used a power cord/surge protector and hit the power switch when not in use. It works well as long as you dont have to rest things like clocks and pre sets.
Any recommendations on which one? or are they all pretty much the same?Sharp Aqous 40" LCD
Onkyo TX SR-507 AVR
You can also find the Kill-A-Watt, or at least a clone at a Harbor Freight for about the same price.
OP, you must really pay alot for electricity don't you....although I think the $100 savings is annual rather than per month, although you *might* be able to do that, I doubt it unless you live in a mansion, or have one of those giant Christmas light displays.
BGE has kindly raised our rates alot over the past couple years...I think that I pay about $.12/kwh or so, and my last bill was like $140 a month for standard usage (970Kwh or so).Home:
Onkyo TX-6500MKII/Polk LSI 9's (A)Polk TSi 100(B)/Polk PSW 10/Onkyo C-S5VL/Technics SL-QD33
Home 2 (Playback):
Dynaudio BM5A MKII/Dynaudio SUB 250MC/Audigy 2 ZS
College:
JBL LSR 2325P/JBL 2310SP/MOTU UltraLite MKIII -
I think I pay .145/kwhr, this of course depends on the time of year. I really have nothing plugged in but my fridge and air condition unit. The power strips are great for keeping things off standby. I think in Europe electronics have to have a switch to actually turn off the equipment and not just put it in standby.
On average I do save about $100 a month, but I was misleading. This is total utility bill. I also conserve water by collecting water from the shower while the water heats up and use this to water plants and flush he toilet.
I just ordered the Onkyo TX-sr707 from 6ave.com for $469! Can't wait to get it. -
Ours is 2100SQft and our bills are always less than 100$ summer maybe 120$ with C/A. Our desktop is never turned off the same with our laptop. My Rotel is always on as is my Sonance. Nothing gets unplugged.
