RTi A5's Driver Quality
Just picked up my New RTi A'5 ($219 each) and noticed the driver material is different than the RTiA7's or RTiA9's. Polk spec comparison states that the A5 drivers are polymer/mica vs polymer composite for the A7/A9. I remember a techie type going on about driver material but can not remember specifics. Any speaker specialists out there? Would like to know before I fire them up. Thanks for your input.
Post edited by Murray1 on
Thats a poly glass compsite then...should last about forever.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Where did you get your A5s for $220 a piece? I am looking to buy some and can afford just about that much?
