Are my SDA's Franken-SDA's?
jimreeves
jimreeves Posts: 57
edited December 2009 in Vintage Speakers
My SDA-1A's came to me with Peerless cloth dome tweeters in them. The guy I bought them from got them that way.
Does anyone know if this was a standard modification for SDA-1A's? I've heard about it with CRS's before but not these.
Jim
Infinity QLS1, Polk SDA-1A, OLAdvent Econowave, Yamaha RXV-1300, CDC-685, P2200, AB International 9220A, Rane ME15B, Cambridge Audio 640P, Grant Fidelity B-283, Luxman PD277-AT7V, Pioneer PL707-Denon DL-207, DL-160....And projects on the bench!
Post edited by jimreeves on
    heiney9 Posts: 25,497
    Probably need pics. How do you know they are peerless tweets other than the guy telling you?
    There is no 'peerless' mod for any SDA that I am aware of. Where did you hear about it for the CRS's?
  • jimreeves
    jimreeves Posts: 57
    Somewhere in this forum. I'll have to look for those threads again. Here's a link to pics of the tweets.
    http://www.polkaudio.com/forums/showpost.php?p=1027160&postcount=147
    I have pics of the speakers at home I can post later.
    Jim
    Yep, those are Peerless and they were never used in SDA's so they were added by someone along the line. The electrical characteristics are different than the original tweets and different than the RD0's.
    Do you have any idea what the original tweets were? You can use the RD0194-1 as orgonal equivalents. I recommend you do this before you do any kind of X-over mods or other mods.
  • jimreeves
    jimreeves Posts: 57
    I'm guessing the originals were SL-1000's or 2000's, I've heard plenty of comments that those were harsh or at least overly bright. These actually sound wonderful as is. I mostly asked because I was curious if anyone had heard of this as a mod from years back.
    Jim
    F1nut Posts: 51,999
    Someone added those, as H9 stated, SDA's never came with peerless tweeters. Those Polk speakers that came with Peerless tweeters always had them mounted with the coiled wires pointed down, not up as in your picture.
    The original tweeters for your model would have been SL1000's.
  • jimreeves
    jimreeves Posts: 57
    My mistake, it appears that all of the threads I've seen re: peerless have been for Monitor Series speakers. Is there a big difference?
    Can you gurus tell me what the impedance of the SL-1000's is?
    In any case, thanks so much for the advice!
    Jim
  • kcoc321
    kcoc321 Posts: 1,788
    I am not a 'guru' but I can tell you I checked one of mine and it reads 6.8o (DCR)
    they are from a Mon7
  • Face
    Face Posts: 14,340
    Even though it's not right, they may even sound better that way. :D
  • jimreeves
    jimreeves Posts: 57
    Face wrote: »
    Thanks Face, who knows, my ears may be the weak link in my system.:rolleyes:
    Any guesses about the impedance of the original tweets?
  • jimreeves
    jimreeves Posts: 57
    OOPs, missed that Kcoc321, thanks. SL-1000 right?
  • Face
    Face Posts: 14,340
    It was a stab at the SL1000, not your ears.
    Don't know the impedance, but in all Monitor series where the Peerless was used they had an extra resistor in the circuit compared to Monitor series using other tweeters.
    Not saying it sounds bad, it's just not the right tweeter for the circuit in the SDA's. Not sure how you make it "correct" in the x-over.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    If you decide to replace them with the correct tweeters, I'll take the Peerless tweets off your hand. At least two of them...if not all four.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    Tony M Posts: 11,725
    :D....I'd like to hear those for sure....:D
    I see a road trip for some people ..
  • jimreeves
    jimreeves Posts: 57
    Face wrote: »
    I figured that from what has been posted before regarding the older polk tweeters. My point was that I don't have any precise way to tell if they sound wrong. My only frame of reference is comparison with some other speakers I have and recordings I'm very familiar with. They sound right to my old ears!
    I did go through the crossovers some months ago to repair some mods done by a previous owner but I haven't changed any components or values.
    From what I've read it seems that some folks think the Peerless tweets are more laid back than the originals, so I'm curious why added resistance would be needed. Maybe too efficient in those particular Monitor Series models?
    I don't think I'll be looking to replace these tweeters for the time being.
    Jim
    jimreeves wrote: »
    Jim
    Speaker mods are NOT my expertise but I will say that those peerless tweeters make those SDAs look 'sweet'!
    cnh
  • jimreeves
    jimreeves Posts: 57
    Thanks cnh, more pics
    You can also see where the Peerless bezel is slightly smaller than the other Polk tweets (sl1000, sl2000, RD0194-1, RD0198-1) so it looks like "filler" was used to make it fit the opening. Have you checked to make 100% sure there are no air leaks around the tweets? Just a thought.
  • jimreeves
    jimreeves Posts: 57
    The filler you see there is rope caulk, seals them well but looks like a$$. I'll have to do something about that.
  • gdb
    gdb Posts: 6,012
    You might consider selling the "incorrect" Peerless tweeters and using the proceeds to purchase some new RDO units from Polk CS. There is a large group of vintage Polk owners that covet the old Peerless, some have paid nearly the price of an RDO for them. Just sayin....;)
  • jimreeves
    jimreeves Posts: 57
    I get that these Peerless tweeters are "incorrect". Here's my dilemma, I like the way these sound now. Everyone seems to say that the stock tweeters sound harsh. Polk introduced the RDO194 as a replacement for SDA?? speakers as a upgrade, which I've never heard and can't be sure I'd like. These speakers, being that they are 1A's, aren't highly sought after anyway. Why was it that I wanted to change them?:confused:
    Jim
  • gdb
    gdb Posts: 6,012
    I don't know the technical aspects of using the Peerless in those SDAs but, if someone who knows, can assure you that nothing is being "harmed" by their use, well.......Rock ON !!! They certainly beat the Bejeezus out of the original SL2000s IMO !!:D
