Just got some Rti8's
Just picked up some Rti8's and was wondering would they sound alright paired with my cs2 center or should i upgrade to a csi to match the new speakers? I also moved the monitor 60's that were the fronts to the surrounds.
Post edited by JujuR6 on
Try it and find out. It may work fine, just because it isn't voice matched doesn't mean it doesn't sound fine. If you don't like it then upgrade to the CSI.Home:
Onkyo TX-6500MKII/Polk LSI 9's (A)Polk TSi 100(B)/Polk PSW 10/Onkyo C-S5VL/Technics SL-QD33
Home 2 (Playback):
Dynaudio BM5A MKII/Dynaudio SUB 250MC/Audigy 2 ZS
College:
JBL LSR 2325P/JBL 2310SP/MOTU UltraLite MKIII -
Ideally you want the center and fronts to be from the same series.
I would try it out and see what you think. If it sounds good to you then keep it. If you notice a difference then i would upgrade. Or if you are like me and it all has to match go ahead and upgrade.
Best of luck and welcome.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
That will work but the CSi will sound a lot better with the RTI-8s...so you should consider the upgrade eventually...60s in the back won't be much of a problem at all....only the 3 front really need to be voice matched.
Welcome to the Club!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I had my 60s as surrounds for a few months, let me know what you think of them. I had a feeling they would do better on blocks or something, that they were just too low to the ground to provide the proper surround experience
I would see if you can find a csi center to try, I thought my csi3 sounded good with the pair of speakers I made for my fronts but when I made a new center to match my front left and right I was amazed at how much better it sounded matched.
go with the csi, you'll be a lot happier in the long run, I can't wait untill I upgrade my center to match my rtiA5'sHome TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
