Ripping my CD's, have some questions
steveinaz
steveinaz Posts: 19,545
edited January 2011 in 2 Channel Audio
I have EAC, Flac, and WinAmp downloaded and installed. I think all my settings are optimized in EAC correctly, and I have it configured to use Flac, but I have some questions.
As long as it takes to rip CD's, I want to make sure I do it right the first time. Is there anything I should know? I just created a "Music" folder on my 500GB external HDD, and that's where I want to put all the *.flac files---is this ok?
Any other hints before I dig knee-deep into about 600 CD's? Should I do a certain directory structure, or is what I have fine?
Any help/suggestions is greatly appreciated. I have ripped 3 albums so far, and everything seems fine.
Post edited by steveinaz on
  • madmax
    madmax Posts: 12,434
    edited November 2009
    My advice is to start by ripping a limited number of discs at first. I did this and found out after about disc number 10 there was some setting I was not aware of. I was only using the windows software (newbie at this).
    Vinyl, the final frontier...
  • mmadden28
    mmadden28 Posts: 4,283
    Read all the FAQ'a from EAC's website.
    Go through the post install steps, etc.
    I also installed AutoFLAC and it's install also had some suggestions for some EAC command line settings.
    I've ripped over 150 CDs in the past week or two - as long as the "confidence' level is more than at least 1 or 2, then you got a good rip (except the less popular CDs that haven't been uploaded into the AccurateRip dB yet). The Confidence level is how many others have ripped their CDs, computed the checksums and uploaded them to Accurate Rip (built into EAC). If the checksum is the same and others are getting the same, then you can rest assured that your rip was good. A lot of the options have to do with how the files are named, log settings, automation settings and compression levels (I left mine at default '6' - the checksums are computed on the uncompressed WAV). A few affect error correctiona dn detections and such. The most imnportant thing is that the rip is accurate IMO.
    I've only had a few small issues, but most of them were caused by some of my older CDs that were pretty scratched up. I just did a quick polish on them with McGuire's ScratchX 2.0 and I resolved 98% or any read errors I was getting except for any seriously damaged discs. Of the ones that did not ripp 100% correct, the log report tells you the time in the tracks where the error is, and in everyone I've listened to I didn't hear any anomalies.
    You will need a scratched up CD to do a proper C2 test.
    ____________________
    Pool: Atrium 60's/45's
    heiney9 Posts: 25,432
    Tagging is important at the time of the rip. I believe EAC allows you to use one of the free internet databases to auto tag your songs.
  • m00npie
    m00npie Posts: 697
    http://carltonbale.com/cd-audio-extraction
    I use the settings as described on this site and follow the directions where it requires setup locally to your machine such as testing your drive for READ features.
  • vc69
    vc69 Posts: 2,500
    heiney9 wrote: »
    +1 thousand!
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • steveinaz
    What do you mean by tagging? I did enter the recommended command string in EAC when using Flac, is this what you are talking about?
    All my titles, file names, etc appear to be correct.
    MMadden-so far the confidence ratings have been very good. I did have 1 CD that couldn't be read??? It's in perfect shape, maybe copy protection? It's ABBA GOLD.
  • steveinaz
    m00npie wrote: »
    Thanks for that guide, I just re-configured mine to match.
  • sucks2beme
    sucks2beme Posts: 5,683
    steveinaz wrote: »
    Or it's an older disc. I had some that couldn't be ripped. I got errors.
    I know for a fact that some CDP's had trouble with them(thePioneer Elites).
    No surface damage. The only thing in common is they were all from about
    1985-86 era. I really didn't want to re-buy them, so I cheated. I copied
    them using cheap software, and then ripped them. I worked, but you can
    hear a bit of what was wrong with them (harshness in spots).
    I think QC was less than perfect in the early years of CD. God knows
    the CD remastering on some of them sound pretty horrid. It's a wonder the
    format survived all the stupid hurried rush of the early years.
    Steve, a tag is the song title, artist, etc......that's embedded into the file. You can't "tag" WAV files. If you don't tag them correctly or at all then when you "import" them into a player or music server the name of the song and artist won't show up and then you have no idea what's playing.
    Giving each file a name in Windows is not the same as tagging. I know EAC tags, just need to amke sure it's set-up correctly................sound like it is.
    If when you play your files using the WINAMP player, if the artist and song title shows up then your files are being tagged. Most times a free music database is used to "auto tag" but sometimes it doesn;t recognize it properly or that particular cd isn;t in the database then you have to manually enter "tag" the information.
  • adam2434
    adam2434 Posts: 995
    Steve, tagging is independent of the file name and puts all the appropriate metadata "in" the flac file itself. Proper tagging is necessary for managing and playing your library in the playback software.
    Most of your CDs will be tagged properly in EAC if you go to Database -> Get CD Information From -> Remote freedb. You may find some spelling errors and other things you may want to edit once freedb finds the info.
    You may have some more obscure CDs that are not in freedb. You can manually enter the metadata in EAC so that you will have proper tags.
    EAC can be set up to create folders for artist with album/CD folders under each artist. A specific folder structure is not critical, whereas proper tagging is.
    How big is the hard drive on your PC? If you have enough space, I would rip to your PC's HD, then back up to the external. As a rule of thumb, you should get around 3 CDs per gb with flac, so your 600 CDs would take around 200 gb, give or take. If you don't have room on your PC, you should still plan to have a back-up on another external HD or some other storage medium. You definitely don't want to lose the files if a HD craps out on you - too much time invested.
    Lastly, you may want to consider Foobar as your player software, as it is one of the audiophile standards for PC music playback.
    Once you get the ripping down, playback optimization will be the next thing to tackle. How will you be playing the music - Squeezebox or USB DAC or USB to SPDIF converter/DAC?
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • steveinaz
    Thanks Fellas
    H9, the info displays properly when playing in WinAmp; Artist/Title/Year/Genre, etc so I guess I have them tagged appropriately. The new tags from the guide above also is automatically creating a sub-directory for each artist on my F:\music\*.* drive. Is this ok? ("F" being my external HDD)
    Adam, ultimately the music will most likely be used with a Squeezebox. My internal HDD is very small (40GB), my new external is 500GB, this is where I'm writing the *.flac files.
    I assume the logitech will have its own cataloging/playback front-end software right?
    steveinaz wrote: »
    Correct............but tags are universal when done properly, which sounds like yours are.
  • adam2434
    adam2434 Posts: 995
    Steve, OK.
    I would still suggest you pick-up another external HD as a back-up.
    You would see a grown man cry if I lost my files (around 700 CDs) due to a drive failure. The thought of re-ripping gives a sinking feeling in my stomach. :)
    Edit: and I would only have the back-up drive connected/on when doing a back-up.
  • steveinaz
    Will do, given the amount of time it takes, a backup drive will be purchased--thanks for the advice.
    H9, thanks man for all the help.
    I have developed a number of databases at work, so I'm very familiar with making sure you've got the proper structure, and capturing all the data you want out of the gate; that's why all the questions, just wanted to make sure I wasn't missing something critical.
    THANK YOU ALL for the suggestions and help, as time consuming as this is, it definitely helps to get it right the first time.
  • louhamilton
    louhamilton Posts: 209
    This is why ALAC with iTunes is so much easier. ;) You put the disc in and it is just "right."
    I did FLAC about 5 or 6 years ago and I remember the PITA that it was. Apple was my savior with ALAC and iTunes/iPod/iPhone/Apple TV for management and streaming.
  • steveinaz
    How do I edit tagged information?
  • mmadden28
    You can edit the tags in any app that works with FLAC, such as MediaMonkey, WinAMP, FooBar, etc.
  • steveinaz
    Cool, thanks.
  • D.Invax
    D.Invax Posts: 7
    Hi Everyone.Just have a quick question about ripping cds onto the mozaic using the software which comes with it.
    Im used to ripping cds and loading them onto my creative zen V plus using the software which came with it. It is very simple as the track names are downloaded from gracenote, the cd is ripped and the album is automatically saved onto the player and my computer in wma format. I was wondering is it possible to do so with the Mozaic software?
    It is important as i have a large cd collection which i need to rip. And i want to buy the 16gb Mozaic.
    Thanks in advance
  • steveinaz
    D-
    You might want to start a new thread, they'll probably assume this one is concluded...
  • sucks2beme
    Note: if you have any mixed media cd's, you would open EAC, hold the shift key
    down while loading in the cd, and hlod it for a few seconds after the tray closes. I had to do this to rip the new Beatles remasters. They put a
    mini-documentery on the disc to to mess me up!
  • mmadden28
    I ran into similar issues when using AutoFLAC with EAC when ripping any CDs that also had data. But when I used EAC by itself I didn't have any issues. I'm guessing you had EAC set to autorip?
  • steveinaz
    My Beatles remasters were ripped yesterday with no issues. I'm not using Autoflac, however.
  • RandyWilliamson
    RandyWilliamson Posts: 178
    I just want to thank everyone.
    I came on here looking for a solution and it pretty much seems like that is what this is.
    So thanks! and I hope you guys had a great Thanksgiving.
    I have a spare laptop that I wanted to use to play MP3'z from on my 2ch Rig and possibly rip some CD's onto....my laptop is not highend it's a little older but should do the trick.
    Now it seems I will be building a flac/mp3 player/ripper.
    Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
    Benq W5000
    "Leaning back like a maxwell tape commercial listening to pure polk bliss"
  • sucks2beme
    mmadden28 wrote: »
    Yup. The data file hoses it up pretty good.
  • !Jeremy
    !Jeremy Posts: 17
    edited December 2009
    I use Windows Media Player 12 and rip my collection to WMA lossless. The tagging software built into WMP works well automatically detecting the CD and populating the files with the correct data. I server the music using a Windows Media Center to a Windows media extender enabled receiver which makes the entire process painless. As long as you have no burn errors WMA lossless will be bit for bit the same data as the PCM data.
  • audiobliss
    audiobliss Posts: 12,518
    edited January 2011
    So, to revive an old thread...
    I've now embarked on re-ripping all my CD's using EAC and EAC's included FLAC encoder to rip to FLAC. I set up EAC so my files are named by just the track name, as I don't want the track number to be a part of the file name. However, I do want my music to be sorted (within their respective album folders) in windows explorer to be sorted by track number. Is there anyway to have the files sorted by track number when that is not part of the file name? I feel like there should be a way, but I haven't found it so far.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • wayne3burk
    wayne3burk Posts: 939
    edited January 2011
    if you sort your files by date -- they'll be sorted in the order they're ripped... but that won't help you in your audio player software.
    If you want them to play in the order they appear on the disc i think you're gonna havta put the 01, 02, 03, 04 ... back in there
    -- wayne --
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • audiobliss
    edited January 2011
    Foobar2k recognizes the track numbers and lists them in that order just fine, regardless of the file name. However, I still want the songs to be listed in that order in Windows Explorer. Perhaps your idea on that front will work.
    I was expecting there to be some way to get that result using ID3 tags, but I must admit I'm not familiar at with them.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • wayne3burk
    edited January 2011
    I wasn't aware that foobar recognizes the track number without the number as part of the title..
    I'll have to give foobar a test drive
    thanks,
