Monitor40's to RtiA3 upgrade, worth it? No need to worry that RTiA3 isn't MTM?
DataOrb
DataOrb Posts: 3
edited December 2009 in Speakers
Hi guys,
I got a good deal on upgrading my current setup (Polk Monitor 40 fronts, CS1 center) to an a new RTiA3 + CSiA4 setup. My usage is 80% HT/Gaming and about 20% music listening.
Will the upgrade truly feel like an upgrade to me?
I'm actually a bit worried that replacing an MTM speaker with two midwoofers (Monitor 40) with a single midwoofer speaker (RTiA3), even one with a larger woofer, will downgrade the bass response of the fronts and may also impact the soundstage / power of the fronts. I'm worried that while music may improve in clarity, the home cinema experience compared to the Monitor40's might suffer.
Any opinions on this? What do you think?
Thanks!
Post edited by DataOrb on
  • MrGlobe
    MrGlobe Posts: 401
    edited November 2009
    Well, I was always really impressed with the low end response of the monitor 40s. When compared A/B with my Monitor 60s, the tossup often goes to the 40s, especially when it comes to hip hop
  • Erik Tracy
    Erik Tracy Posts: 4,673
    DataOrb wrote: »
    Hi guys,
    Thanks!
    What do you have driving your speakers now? Will that be upgraded, too?
    I run RTiA3s for mains, CSi3 as a center, and an Epik Valor for my sub. The RTiA3s are generously fed whatever power they need with a modified Carver amp - and I can *rock* the house for HT with some hard chest thumping LFE with a single sub and a big spacious soundstage with great dynamics and clarity with the RTiA3s.
    Depending on your setup you can also move the RTiA3s closer to the wall so that you get more bass re-inforcement via the rear firing power port if you want more bass.
    I'd say you are going to hear a noticable upgrade in sound! :D
  • mystik610
    mystik610 Posts: 699
    DataOrb wrote: »
    Hi guys,
    Thanks!
    The RTi-A line are a different league from the Monitor Line. Far more detailed, better imaging, and downright pristine clarity. They may be a little bright for music, but for HT/Gaming, they'll bring out audio details that you were missing with the Monitor 40's.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • DataOrb
    DataOrb Posts: 3
    My complete setup, currenty:
    Monitor 40s in the front.
    CS1 as the center ( a bit dissapointed with it, it doesn't dominate the soundstage enough for me compared to my Monitor 40s - the main reason why I want to upgrade to the CSi4 and along the way the RTiA3 as well).
    Polk PSW100 Subwoofer.
    Morel LI-1 MK1 satellites as rears.
    Driving my setup is a YAMAHA RX-V663 (my 40s are bi-amped by the reciever).
    I'm sure the RTiA3 are superior when it comes to clarity and imagning, no doubt.
    I'm just wondering what am I going to loose by going with a single-woofer speaker (RTi) compared to a two-woofer speaker (40s)? Something in the sound has to go , right? Even while the cabinet and elemnets are way better in the RTi, doesn't the second midwoofer in the 40 add additional punch to the sound? Has anyone heared the two side-by-side?
    Oh, and btw, any reason the RTiA1 are listed as having "dual 5-way binding posts" while the RTiA3 only said to have "5-way binding posts"? (no dual).
    http://www.polkaudio.com/homeaudio/rtia/specs.php#bookshelf
    I can Bi-Amp the RTiA3, right?
  • Erik Tracy
    DataOrb wrote: »
    I don't think you will give up much, if anything, by going to the RTiA3.
    Spec-wise, they reach lower than the Monitor 40s.
    I've run my RTiA3s from my AVR in "Pure Direct" mode with no subwoofer at all - and I swear, several times I've gotten up to put my ear next to the subwoofer just to make sure nothing is coming out - cuz the bass still sounds full.
    The spec sheet on the RTiA3 has a typo - yes they are 'dual' binding posts (+ and -) and yes you can bi-wire or bi-amp the RTiA3s.
    I'm in agreement with most of the above...the main difference with the Rti bookshelves is that they have more detailed and sometimes overly bright tweeter..but that's very dependent on what you use to drive them.
    Whereas you can get away with driving M40s with a Yamaha and they'll sound OK....the Rti-A3s will sound harsh with that AVR when played mid-loud volumes...that's not a good match....I would consider another AVR if you're going with Rtis!
    Monitor speakers are more forgiving but less 'detailed' than Rtis....that may be an advantage for some people with brighter AVRs and amps?
    cnh
  • DataOrb
    DataOrb Posts: 3
    Hi guys,
    Took your advice and bought the RTiA3 + CSiA4. Can't wait to hook them up to my setup !
    Many thanks!
    Btw, if I'm already in the process of upgrading my system, would you recommend the RM8 rears to compliment the RTiA3 + CSiA4?
  • mystik610
    DataOrb wrote: »
    Hi guys,
    Many thanks!
    Ideally you'd wanna get another set of RTi A3's or a pair of FXi A3's for the rears to keep everything voice-matched.
    My System Showcase!
    Media Room
    Living-room
    Headphones
  • SivaNevets
    SivaNevets Posts: 303
    RTIA3 is a awesome set of speakers! im so glad i bought them (RTI6). I have played them for 3 months now they sound better than ever.
    I would get another set of RTIA3 for rears, because they went fairly low (im satisfied for 2 channel listening) so u can cross them at very low for rear use (i would say 40hz).
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
  • saleens7turb0
    saleens7turb0 Posts: 11
    I was wondering if I should get monitor 40's or tsi200 or RTi4. I am looking for them as rear surround speakers. I am kinda budget in mind but will pay more for a much better speaker. I see on new egg you can get monitor 40's for 129.99. The tsi200 I can't find under 300. Is it worth over double the price?
    Rti10's - Front Speakers
    Csi3 - mid Front Speaker
    PSW10 - Sub
    Pioneer 5 channel receiver
    Graham
  • packetjones
    packetjones Posts: 1,059
    in my opinion they are not worth double the price. the TSI and monitors are very similar with the TSI's having a nicer cabinet and a piano gloss top. the specs on the speaker are very similar. A friend of mine has 40's for surrounds and they sound good and he loves them. Personally i would get the RTi4's. The only reason is that i like the matching surrounds and you already have the RTi line of speakers based on your sig.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • saleens7turb0
    Sweet, Thanks a lot for the help!
    PSW10 - Sub
    Graham
