matching center for RTI A5's
bhoup
bhoup Posts: 2
edited October 2009 in Speakers
Hello. I need to purchase a center channel to match my RTI A5's that I recently got. Does anyone know if there is much difference between the CSI3 and the CSI A4?
Also, for the surrounds should I go with less $ and get the OWM's or more $ and get the FXI A4's?
Post edited by bhoup on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2009
    Csi a4 for the center and fxi a4's for the surround would match perfectly. If you're on a budget the other two options will work.
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2009
    I'd suggest the bigger CSiA6 center channel and then save some money with OWM3 surrounds. There's not a huge tonal shift between the newer CSiA center channels and the older CSi but it exists. I'd stick with the same series for your front stage and less worry on the surrounds.
  • renowilliams
    renowilliams Posts: 920
    edited October 2009
    I use a csi40 for center and find it works great. You may be able to locate a good used one.
    Good Luck
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • packetjones
    packetjones Posts: 1,059
    edited October 2009
    I have the CSiA4 for my center. I am limited by the space that i need it to fit into. Most people say to get the A6 as 50-75% of dialogue in movies comes through the center. If you can fit the larger center i would get the A6. If money is tight then the older version of the RTi centers would work too.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
