Picked up some Monitor 10B's--Couple questions...
mmadden28
And picked up a pair of Monitor 10Bs with the stands on Sun afternoon (CL).
These aren't as in great a shape as the 5B's I got on Sat.. They have a few nicks here and there along the back edge and corners, but the sides, top and fronts look pretty good, esp in the Rosewood finish. Looks like one driver was replaced recently as it doesn't have as much extension as the others and has the obvious texture difference as well as the lack of cutouts in the surround for the screws. They have the SL1000(???) tweeters.
The grills need re-clothing, and they are quite dusty. (What the heck is up with people not cleaning stuff up before they sell it???)
I turned down the heavy gauge Monster speaker wire he was throwing in with it.
I already have a pair of 10A's with Peerless in Walnut--so I might do some comparisons. Other than the tweeter difference--What's the difference between the 10A and 10B?
Also, I think it's an oddity, but on one speaker there is a fuse, but not on the other. The 10A's I have, have a fuse on each speaker. Is this normal?
Now I know what those three little holes are on the binding post plate--its a leftover from the fuse--at least that is what I think it is, the middle hole for securing the fuse holder and each other hole for the wires to pass. My SRS2's have those three holes but on the inside they are sealed with glue.
Here's a couple pics of each binding post plate--Note the serial #s aren't that far off from each other
And a couple pics of them:
These are in definite need of a good cleaning--can you pick out the new driver? Which one of these is not like the other
____________________
Pool: Atrium 60's/45's
Post edited by mmadden28 on
SWEET!
I'll take the inner driver (closest to the opposite speaker) on the right cabinet for $500! lol
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask -
Is that song from Sesame Street stuck in anybody's head right now?____________________
Pool: Atrium 60's/45's -
Yes, SL1000's
The ones without the fuses have Poly-Switches, I like the fuses better. Some say the Poly-Switch can color the sound.
Also, you can use windex to clean off that brown oxidation on the drivers.
Yeah but one with a fuse and one without? in the same pair? Those S/N are within 43 of each other.
Yeah, I'll be giving them a good cleaning, I only just got them home and wanted to hook em up to hear them first--They sound good--real good.:cool:____________________
Again, nice pics! Congrats on the find!
James2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player -
INside driver, right spekaer for sure.
sTiLlLeArNiNg wrote: »SWEET!
JohnLocke88 wrote: »INside driver, right spekaer for sure.
+1
The ripples in the outer edge of the surrounds, due to the lack of cutouts for the screws, give it away.
It's also a bit blacker looking.
Congrats! Yours must must have been produced during a transitional period...
I'm not sure if that would result in any audible differences between the two...but I doubt it. As long as the crossovers are still the same.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »+1
I have yet to pull them, or even clean them...:o____________________
