The sda 1a's are home
keith allen
keith allen Posts: 734
edited October 2009 in Vintage Speakers
I got the 1a's home today,they looked better in person than in pics,they need new grill cloth,and could use a good cleaning on the outside as well.I am powering them with an nad c370,same piece I powered my 2b's with,gotta say I really like the 1a's over the 2b's.One more driver and I believe the cabinets may be a little taller as well,seems like they have a little more punch to them.I replaced the 2b's with a real nice pair of later model m10's which I still have,really have enjoyed them the past few years btu doin comarisons between them and the new 1a's all afternoon,I truely like the sda's better.Thought I would listen to them a while and then move em on,but I think I'll keep them instead,give the m10's a break.Since I only have a $100 in them I may invest in doing the upgrades,Ive read crossover mods are good and modding the inside of the cabinets as well,anything else thats a common upgrade on these I'd appreciate ya'll letting me know.
Thanx in advance
Post edited by keith allen on
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    Congrats. Now you just need to make it over to my place for some tweaks. George is in the area and Jerry. Both stellar Polkies.
    Ben
    Ben
  • keith allen
    edited October 2009
    ben62670 wrote: »
    Ben
    Yea,I would like to have someone involved that knows just what I need and has done it as well.Myself,I have changed a few drivers ,and replaced some binding post but thats about it,nothing to technical.OH,there is also an upgrade on the tweets,right?
  • ben62670
    edited October 2009
    Yep:)
    Ben
    edited October 2009
    Congrats! I have 2Bs myself...and I imagine that that larger box and extra drivers do put out more bass--which is always a good thing..
    cnh
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2009
    Congrats on your new purchase.
  • bigaltx24
    bigaltx24 Posts: 141
    edited October 2009
    Looking good, I've had my 1Bs for about a month now, probably the best $150 I ever spent.
    Denon PMA-900V
    Linn Axis with Grado Red
    Cambridge Azur 650C
    Polk SDA-1BTL
  • thsmith
    thsmith Posts: 6,082
    edited October 2009
    Congrats !
    heiney9 Posts: 25,406
    edited October 2009
    Actually the 1's have 2 more drivers and one more tweeter than the 2B's. Congrats and enjoy!
  • Barefoot
    Barefoot Posts: 149
    edited October 2009
    Those are sweet-looking, Keith. I'm in the final phase of picking my own SDA's. Either going for the 1C's or the 2B's. Still haven't decided, and e-bay/craigslist pickings are currently pretty slim
    (btw, how come the search feature isn't working so I can look up some comparison threads? I type in SDA and nothing comes up)
    Anyway, don't mean to derail. Those are nice looking. How do you like the dimensional tweeter?
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited October 2009
    Try SDA*, you'll get plenty.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • Barefoot
    Barefoot Posts: 149
    edited October 2009
    You're right, thanks. I didn't know to use an asterisk. For some reason it makes all the difference.
  • Disc Jockey
    edited October 2009
    No problem. The search function needs a minimum of four characters and the asterisk just acts as a wildcard.
  • keith allen
    edited October 2009
    Thought I would hook my two carver tfm22 amps up to the sda's, in mono to hear how they sound with big power,but I was foiled because the sda's are not recomended with bridge amps.Oh well I'll swap out my nad c370 with one of the carvers,it will be a good bit more power,we'll see how they sound.The little nad pushes them purdy well,does get a bit warm after a while.
  • BrettT1
    BrettT1 Posts: 560
    edited October 2009
    It's ok as long as you have the AI-1.
  • keith allen
    edited October 2009
    BrettT1 wrote: »
    Could ya explain Brett
  • ben62670
    edited October 2009
    It is a one to one transformer that allows the use of non common ground amps.
    Ben
  • keith allen
    edited October 2009
    Did some searchin on the combonation of carver amps and sda's,this is what I found out.My carvers,tfm22/24 are common ground amps,so they should work well on my sda-1a's.I want to use both amps switched in mono on the 1a's,thats where I'll have a problem,the amps in mono become non common ground.This is where the AI-1 comes in,designed for use in the ic cable and fixes the problem,easy enough...not so fast!My ic cable is dual blade,what I understand is the AI-1 will only work on the blade/pin ic cable of the later sda-1b,1c,if this is so where does this leave me?I'll assume just out of luck.Any input very much appreciated.
