Flat Screen Wall Mounting Bracket: $11
Kex
Kex Posts: 5,241
edited September 2009 in Electronics
Just found this deal on MonoPrice.com $11.05, in case anyone has been looking for a budget solution (shipping is estimated at an additional $5-9):
- Ultra-Slim Fixed Mounting System for Flat Panel Displays.
- Universal, adjustable mounting system.
- Max hole pattern: 824mm wide x 410mm high.
- Min hole pattern: 234mm wide x 58mm high .
- Max VESA: 800x400.
- Max Weight: 75kgs (165 lbs).
- Fits most displays between 37" and 63"*.
Edit: just realized that I forgot the fookin' linky!
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082807&p_id=5918&seq=1&format=2
