Bridging Amps to SDA's
Tour2ma
OK... so I either figure out H2 bridge the M1.5's or I buy bridgable other model Carvers. But with two amps bridged to mono, I would no longer have "common ground" amps.
So how do I hook them to SDA's?
More later,
Tour...
Vox Copuli
Tour...
Vox Copuli
Post edited by Tour2ma on
You've got to use the AI-1 Non-Common Ground Amplifier Interface cable. If your SRS's are s/n 5001 or above you can do this, but the trick is going to be finding one. Maybe Ken has one stashed somewhere or you can build one, I have the specs somewhere, let me find it and I'll send it to you. Sorry bro, you can't have mine.Political Correctness'.........defined
President of Club Polk -
But I might get a look at it in a week or so...
More later,
Tour...
Vox Copuli
You've got mail and don't bet on it.......;)Political Correctness'.........defined
Bi-amping is a very good alternative to bridging.
F1,
Phuleez... I want to see that new Sony ES to boot... I'll be good.
Madmax,
I'll likely do both before it's all over...More later,
Tour...
Vox Copuli
I've ran my Denon Poa 6600's with my SDA's for 10 years now by running a jumper between the negative speaker terminals on the amps. This info was given to me by the denon reps. I don't know if it will work for you on yours though. No problems. I learned about common ground amps the hard way when I brought the denon's home and hooked them up without reading my Polk manual. The resulting noise from my speakers gave me a heart attack! No damage though.SDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
How do you like those Denon's? What are you using for a pre?Political Correctness'.........defined
I'm very satisfied with my 6600's. I bought them from a stereo store in PA as B-stock in 92 I believe for $750 for the pair. I kicked myself for not getting another pair to bi-amp with. I used a HK Citation to power the top end of my speakers which is also a great amp IMO for the money. I sold the HK to a friend before I moved and later got a Soundcraftsman to power the bottom end. It did the job but wasn't quite what I wanted as the fan was a little noisy. The preamp I was using was an Adcom 565. I was very happy with it. That extra pre-outs on the back made bi-amping simple. It was quiet and clear. Lately I decide to go home theater and made some bad decisions in the process. I figured I'd get a rcvr and use the pre-outs so I could keep the 6600's. I went with a Denon 1802 and now I know I should have spent some extra money for a better 2 channel sound quality. I had also sold my California Audio Labs CD player and bought a Panasonic DVD. With all of those changes the sound just isn't close to what it was. So, thanks to my addiction to Ebay I bought another Citation 2 weeks ago that also came with the preamp. Then last week a pair of Denon POA 4400's, this week I "accidently" bought a POA 5000, AVP 5000 preamp, and a tuner! I didn't mean to get all of this crap and I don't need it but I think this is how the setup will go: Denon 6600's for the bottom end and 4400's for the tops of my main speakers. The POA 5000 will bridge 3 channels (I believe) and that will run the center and rear surrounds. I'll use the tuner but I may not use either preamp unless I decide to keep the Citation and put a smaller system in another room. The 1802 is going away....somewhere. Is anyone confused because I know I am! To answer your original question, I wouldn't part with the 6600's, I've never had any problems with them and they sound great. The Adcom 565 is nice too. MitchSDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
Mitch...
How's things at Brunswick NAS?
BDTI plan for the future. - F1Nut
