Which SDA 1's are these?
xj4094dg
xj4094dg Posts: 1,158
edited August 2009 in Vintage Speakers
Not sure if these are 1's, A's, B's or C's.......Anyone?:confused:
Thanks!
"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
Post edited by xj4094dg on
  • Hamatym
    Hamatym Posts: 269
    edited August 2009
    They are for sure either b's or c's, I thought someone here mentioned only the c's came in the real wood tops? I will need confirmation from others if this is true, but either way they look really good!
  • nduitch
    nduitch Posts: 316
    edited August 2009
    Definitely 1C's.
  • george daniel
    george daniel Posts: 12,096
    edited August 2009
    SDA 1C positive id,, lock on target---let us know when you have a purchasing solution. ;)
  • Pauly
    Pauly Posts: 4,519
    edited August 2009
    My old baby's
    Grrrrr
    Pauly
    Life without music would
  • george daniel
    edited August 2009
    Hamatym wrote: »
    The SDA 1C's that I am familar with are the Wood End Cap,, as pictured above,and the "Studio" version.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited August 2009
    Those are minee!!!!!!
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2009
    They are SDA 1C's, not the studio versions but the version just before that. Very nice, I definitely love my pair but think the RD0 upgrade is needed to really enjoy them at high volumes...unless you like bright tweeters.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • nduitch
    nduitch Posts: 316
    edited August 2009
    Bright tweeters are great if you are a saxophonist like myself and you want to hear Michael Brecker and David Sanborn the way they sound live. The RDO's are a little too tame to capture their fury.
  • Pauly
    Pauly Posts: 4,519
    edited August 2009
    nduitch wrote: »
    Watch out you will be lynched for that comment! :D:rolleyes:;)
    Pauly
  • madmike
    madmike Posts: 81
    edited August 2009
    Did those have SL-2000's in them?
  • Bobsama
    Bobsama Posts: 526
    edited August 2009
    Si, senor.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • xj4094dg
    edited August 2009
    I think JohnLock88 picked these up for $249.00!!!!! They were in Chula Vista (aka Chula Juana) south of San Diego. Sweet deal. I missed this deal by one day.......but glad a fellow Polkster got 'em.:D
  • george daniel
    edited August 2009
    Just for the record,,I did not mean to imply that those are the studio's,, here is a pic of the "OTHER" SDA1C
    Actually,, the one to the far left is a SDA 1C w/end cap,,the black one is the studio version.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited August 2009
    nduitch wrote: »
    The 194s do sound a bit tame at first, but with some break in and the right ICs they get all the life the SL2000s had without the hissy sibilance or high frequency ringing that aging 2000s are known for. A good pairing with 194s are Ben's ICs. I was using Dbacks and Corals (very close) for years, plugged Ben's cables into my rig and the highs opened up. They've gotten better ever since. It's been about a year or more and they still get better.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • JohnLocke88
    edited August 2009
    Nope... EVEN I missed them. Someone picked them up this morning. YARGH!
    F1nut Posts: 51,768
    edited August 2009
    Something a lot of folks don't know, all 1C's are studio versions. Polk added the cloth sides and wood end caps over the black vinyl cabinets to make the upscale version.
  • JohnLocke88
    edited August 2009
    Very interesting to know... So conversion one way or the other wouldn't be too difficult...
    F1nut Posts: 51,768
    edited August 2009
    Well, you certainly can't go back to the studio from the upscale version due to the cloth sides being attached with glue and the end caps attached with glue and big **** staples. Going the other direction is doable, but cost wise finding a pair done up already would be much cheaper.
  • george daniel
    edited August 2009
    I did not know that,, so the actual cabinet that houses all the drivers,,etc,, are the same?
    F1nut Posts: 51,768
    edited August 2009
    Yes, the actual cabinet is the same. However, the bezel is slighly different with the PR (not sure about the drivers) moved slightly upwards to allow for the kick plate on the studio version.
