Pioneer BDP51-FD is making my 60's sound bright?
obieone
obieone Posts: 5,077
edited August 2009 in Electronics
So I've got the Pioneer player, and it's hooked up to my SC-05 via a monoprice hdmi 1.3 cable, for BR's and AQ Sidewinders for cd's. Here's the problem: My 60's sound bright, (for the 1st time), and I'm wondering if it's the cables-neither have really played long enough to get 'burned in', the players, OR my speakers fault?
Just looking for feedback, to see if anyone else noticed this with this player:confused:
Post edited by obieone on
  • george daniel
    george daniel Posts: 12,096
    edited August 2009
    I've got the same player,, I would suggest try swapping cables,,which is what I did,,initially I swapped pre's, but went back to the original setup,,you might wanna try something like a MIT-T-2 between the Pioneer and your pre. Good luck,,let us know what happens.
  • george daniel
    edited August 2009
    xcapri79 wrote: »
    The Pioneer BDP-51FD is a fine Bluray and CD player.
    You may notice that your whole frequency response and soundstage improves.
    If you haven't already done so, upgrade your FW to 1.32.
    http://www.pioneerusa.com/PUSA/Support/HomeEntertainment/Blu-rayDisc+DVD/PioneerBlu-rayDiscPlayers/ci.BDP-51FD.Support?tab=B
    This cable burn-in you mention is myth.
    I'm surprised it is still perpetuated on this forum.
    http://sound.westhost.com/madashell.htm#burnin
    http://forum.ecoustics.com/bbs/messages/34579/127865.html
    Cable burn in a myth???? :eek:
    Get ready to rumble.
    Plenty of threads on that,, so lets not start another,, as far as I'm concerned,cables are a personal thing,,I let my ears decide for me.
    Nuff said
  • danz1906
    danz1906 Posts: 5,144
    edited August 2009
    MITs are known to be warm, so that may work.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • obieone
    edited August 2009
    WTF?! I'm trying to do the f/w update, but my pc, won't 'open' the iso file? It's xp?
  • obieone
    edited August 2009
    I followed those directions. I'll explain what I did:
    Downloaded the zipped file to my desktop
    Extracted the file to another file folder on my desktop
    Put a blank CDR in to the burner, and copied the file to the cd.
    I am NOT getting the 'folder' image, but the iso image on the cdr.
    I cannot open the iso image to check the contents???
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2009
    xcapri79 wrote: »
    Well now we know who one of the cowardly tagger are.
  • obieone
    edited August 2009
    C'mon guys, play nice
  • hearingimpared
    edited August 2009
    xcapri79 wrote: »
    Please don't make false assumptions and play fair.
    I hope you hear me.
    Cheers.
    If I am wrong then I apologize but that doesn't let you off the hook for poking fun at my hearing disability for the second time.
  • obieone
    edited August 2009
    Here's what I'm getting, when I right click, or dbl click::
    "Window can not open this file:
    File: BDP_0551FD_Ver132.iso
    To open this file, windows needs to know what program created it. Windows can go online to look it up automatically, or you can manually select from a list of programs on your computer
    what do you want to do?
    Use the web service to find the appropriate program
    or
    select the program from a list"
    When I click on web, it takes me to websites that offer the iso software for $$$?
  • Ricardo
    Ricardo Posts: 10,636
    edited August 2009
    George, he posted some links to the internet, so he must be right.
    SOPA
  • nikolas812
    nikolas812 Posts: 2,915
    edited August 2009
    Correct me if I am wrong.
    but don't you need some sort of ISO burning software?
    I had the same problem with my Sony. Then I downloaded an ISO program off of the internet. An Viola. It worked.
    Disregard if you have already done this..
    Nik
  • hearingimpared
    edited August 2009
    xcapri79 wrote: »
    I didn't know that you actually had a real hearing problem.
    Sorry friend, no harm was meant on my end.
    I thought that your nickname was just a facetious one as so many are.
    I hope you can understand why since this is an audio forum.
    See false assumptions do get us into trouble.
    I hope we are ok now.
    No problem, however I still disagree with you about cable burn in and cables making a difference.:p
  • obieone
    edited August 2009
    LOL! Thanks xcapri79. I'm FINALLY all set. I went in a lot of wrong directions, but I finally got the burning software downloaded off the net, installed and burned the cd for the fw update. Just finished, and rechecked the version.
    Good to go!
    Btw, if anyone needs a Pioneer OFFICIAL disc, I should be receiving mine in about 3 weeks:eek::p
    As a follow up, I checked a couple of other sources besides the 2 I checked, and it appears, it MAY just be the sources, and not anything with my system.
    Thanks again for all the help.
  • Grimster74
    Grimster74 Posts: 2,577
    edited August 2009
    Obieone, if for some reason you still can't get the firmware copied to a disk, PM me you home addy and I'll mail you the disk I made. If it helps I used Nero to create mine so if I could be of any assistance in helping you create one over the phone let me know and I'll PM you my phone number.
  • Grimster74
    edited August 2009
    Nevermind!:D Glad to see you got things taken care of.
  • george daniel
    edited August 2009
    Ricardo wrote: »
    Thanks for pointing that out Ricardo,, don't know what I was thinking.Expect a cable sale from me soon.:rolleyes::cool:
  • superjunior
    superjunior Posts: 1,632
    edited August 2009
    so far from what I've seen, different ics make a huge difference in sound quality. I've switched from monster cable to mit avt3's and my system has never sounded so bright - just horrible. I'm gonna give them more time to burn in, and if my sound doesn't improve, they're outta here.
    jr
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • Montoya
    Montoya Posts: 506
    edited August 2009
    This is the song that never ends.
    It goes on and on my friends.
    Someone started singing it not knowing what it was,
    and they'll continue singing it forever just because,
