Ripping concert dvd's to pc?
obieone
obieone Posts: 5,077
edited January 2010 in Electronics
I just installed a WD ext. HDD, that I forgot I had(duh), and was wondering if it's possible to rip my concert dvd's to my pc, then load them onto the WD, THEN plug it into my SC-05:eek::confused:
I just wasn't sure if there was a software out there-LEGAL please- that would allow this.
I am NOT looking to do this for pirating purposes. JUST convenience;)
Post edited by obieone on
  • John30_30
    John30_30 Posts: 1,024
    edited July 2009
    obieone wrote: »
    DVD-Decrypter (free) will rip them to an Image file which then can be mounted as a virtual drive. It will strip most encryption along the way for painless play.
    Or you could just copy each VIDEO_TS folder to your Hard Drive in its entirety using Windows Explorer, rename it to the particular concert, then navigate to that with your movie software.
  • uncmike
    uncmike Posts: 29
    edited July 2009
    i use anydvd and 1 click dvd copy pro. any dvd runs silently in the background and 1 click dvd copy pro lets you choose the movie only (which saves a ton of space, different subtitles, and audio formats. very easy to use and produces very high quality results.
    I use this set up for vista media center and mymovies, so can't comment on it working with the sc-05.
    this is only illegal if you don't own the original media. all back-up software programs should have similar policies.
    Fronts L/R: Polk Rti-a9
    Center: Polk CSi-a6
    Surrounds L/R: Polk Rti-a7
    Subs: Velodyne DPS12
    Receiver: Denon AVR 4306
    Source: HTPC tower/360 elite
    Panamax Power Conditioner
    AudioQuest Type 4 Cables
  • obieone
    edited July 2009
    Thanks for the feedback. I'll start the research now.
  • renowilliams
    renowilliams Posts: 920
    edited July 2009
    There are a lot of programs that are supposed to get by copyright protection. Theone that I find works best is AnyDvd. Then I use Roxio 10 to do any sort of video encoding. IE: taking a dvd and turning it into an avi.
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • cfrizz
    cfrizz Posts: 13,415
    edited July 2009
    Quite honestly why would you want to? I would much rather watch it through an actual tv & dvd player rather than a pc. It can't possibly look/soud as good on a pc as it does on a tv.
  • Serendipity
    Serendipity Posts: 6,975
    edited July 2009
    cfrizz wrote: »
    I use an HP Digital Entertainment Center z560 for this purpose running Windows XP Media Center, using the projector and Definitives the sound is as good as watching an actual DVD.
    Who says you cant' use a PC as a transport? Just run the Optical out from the PC to your pre and HDMI/DVI out to your TV/projector.
    Then rip the DVDs and you are all set.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • uncmike
    uncmike Posts: 29
    edited July 2009
    cfrizz wrote: »
    Actually, the quality can surpass watching it on 'tv'. Not sure what you mean by that, but you can hook up any pc to any tv via hdmi/dvi or optical out. I watch everything from my media center pc in full 1080p quality.
    Just depends on how you encode, you can copy the media in .VOB format or the original blu-ray format and have excellent quality. You just have to have the right graphics card and enough memory (I have 5.5 Terabytes that store about 500 movies)
    Center: Polk CSi-a6
  • Marty913
    Marty913 Posts: 760
    edited July 2009
    I have a lot of concerts on disk so I’ll throw in a few comments.
    First, the newer concert DVD’s from probably 2000 on will require copy protection removal. DVD Decrypter is a great free program and I still use it for some stuff but it has not been actively supported for 7-8 years so it won’t work on new copy schemes.
    AnyDVD and DVDFab are the two most popular supported programs. FAB has a free version for ripping an entire disc (but not just the movie, the pay version does that). It’s around $50 for the pay version. Don’t know the prices on AnyDVD but thought it was $110 for the full version. Don’t know if the offer a free version like DVDFab but easy to research both.
    If you’re into just certain songs, chapters, or just the music there are a lot of free programs that will rip, segment, combine, re-encode etc. Most will require the copy protection to be removed first. Some examples include DVD Shrink (not supported but works fine on non-CP stuff), SUPER, OXELON, and Format Factory.
    There are a lot of reasons for doing this. The simple convenience of having movies (especially concerts) a few clicks away is obvious. Being able to combine “favorites” is another. Having movies on hard drives is no different than ripping CD’s to FLAC or MP3’s. Sure you can get up and change CD’s but why would you want to? It’s the same with movies. I have a $90 WDTV box with a couple of USB hard drives plugged into it. HDMI / Optical into the system and you’re watching 1080p concerts with menus, Dolby & DTS, and the same or better quality than the disc.
    A PC will do it also as mentioned. The only drawbacks there are that the PC must be capable power-wise, have HDMI output (or a video card added), and it usually does tie up the PC. Also a lot more power / heat used plus connection to the TV / sound system may require that it be fairly close. I would not say that “any PC can plug into any TV and be used". A laptop can be an OK alternative but you may spend as much on cable converters and sound card add-ons as getting a $90 box to do it.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
    edited July 2009
    Marty above has pretty much summed up what I use myself. But the industry is ABSURDLY regulated in such a way that you can't even legally copy what you OWN! Copy protection would require you to strip it off even if it were for PERSONAL use!
    All this stuff will go away in the next decade or so as INDEPENDENT film online explodes and HD-cameras allow ANYONE to make a low budget film and distribute it on the internet....maybe we'll get more and better FILMS and allow more Artists to express themselves than just the RIDICULOUSLY small group that Hollywood funds and recognizes...THAT IS A MONOPOLY of the worst proportions!
    You own it. Don't worry!
    cnh
  • obieone
    edited July 2009
    cfrizz wrote: »
    Not going to watch them on my pc. I'll rip them onto my pc, then load on to an external hard drive, which THEN plugs into my Pioneer SC-05, via a USB port on the front.
    I don't care about the video, just want as much music as possible, like a music server:)
  • cfrizz
    edited July 2009
    Ahhh. Ok I gotcha!
  • apphd
    apphd Posts: 1,514
    edited September 2009
    ^^^^^^^^Reported^^^^^^^
  • emoxley
    emoxley Posts: 205
    No matter what software you use, technically, it's not legal at all. Because to rip them, you have to bypass copy protection, which is totally illegal, for any reason. We had this discussion recently in another thread. When you buy the movie (concert), you don't own it. The studio still owns it. You bought the right to watch it anytime you want. It says on every dvd you buy, that's it's illegal to copy, even when no monetary gain is involved.
    The police or FBI aren't gonna come knocking on your door, unless you sell copies.
    You asked if there is software to let you rip them to your PC legally, and technically, the answer is NO. Just FYI..........
    Samsung HL61A750 LED DLP
    Onkyo TX-SR805 receiver
    Oppo BDP-83 blu ray player
    Polk Audio LSi9 front speakers
    Polk Audio LSiC center speaker
    Sony SS-MB100H rear speakers
    SVS PC12-NSD powered subwoofer
    Pioneer PL-514 turntable
    Logitech Harmony 628 Universal Remote
  • bighorsietoe
    bighorsietoe Posts: 7
    edited January 2010
    It's $60 for a lifetime membershop but well worth it. You can rip,burn, convert formats, copy and edit all the DVDs and CDs you care to without headaches.
