SDA's in Gainesville Fl.
StevieB
Maybe 1b's? Tweeters look odd, but the price is right. http://gainesville.craigslist.org/ele/1274040296.html
McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
Post edited by StevieB on
Yep...1B's.
One of them is missing the pedestal, and one tweeter doesn't work...but at $90 it's a steal. Make a new pedestal and buy four RD0-194's and you'd still getting them at a killer price.
edit-It looks like some of the dust caps on the MW's are pushed in too...The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
They'll make a nice project speaker.
Go pick them up, worst you could do is sell them and make a little pocket change. -
For the price jump on it. you can get the right tweeter pretty easy to make it right. Good start to an easy rebuild IMO.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
great price... wonder if the seller's price is negotiable
then it could be even better deal. -
I need to go to G'ville on Friday...may try to take a look if they are still there.McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
They would already be gone if they were here in Colorado.
I would have no problem in fixing them up for that price. -
That'd be only $11.25 per MW6509 if you needed some.
10-4 on snagging them. You could refurb these and make a little profit in the end. I say go for it.
