using crs' for center channel and surrounds
maandjojo
maandjojo Posts: 293
edited June 2009 in Vintage Speakers
I have two sets of crs' one with rdo single tweeters and the other with the old dual tweeters. On Sunday picking up one of blue comets sda srs 2s' and I am going to use the single tweeters crs' for the surrounds and one of the dual tweeter crs' for the center channel.
Do you suggest I use the interconnect for the surrounds?
For the center channel, I have disconnected the array tweeter, should I leave it that way or reconnect it? I know that when the interconnect cable is not used the speakers works the same way as a standard speaker but will both tweeters and drivers fire up?
Please let me know, tomorrow I am going to set those up so Sunday I can just hook those srs' up and play all day.
Thanks,
Joe:
:confused:
Joe
Post edited by maandjojo on
  • bluecomet
    bluecomet Posts: 1,118
    edited June 2009
    Hi Joe, I am going to chime in and suggest you use the the single tweeter CRS+ for your center channel. That set has better crossovers and the center main is more important than the surrounds to be right on the money sonically. I am not sure about using your interconnect cable for the surrounds. If you use a 6.1 system you can use that other CRS+ speaker for the center rear. Maybe someone else has some experience with using CRS speakers for surrounds. I will be interested to hear from other mambers if they agree.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • Rivrrat
    Rivrrat Posts: 2,101
    edited June 2009
    You all have a lot more room than I do if you're using a crs as a center channel.
    My equipment sig felt inadequate and deleted itself.
  • maandjojo
    edited June 2009
    Not really, built a shelf over top of the tv. The one thing great about a pair of srs' is that you do not need to separate them as much as other floorstanders.
    Joe
