What's Your Record Cleaner Solution Recipe?
rtart
rtart Posts: 855
edited June 2009 in 2 Channel Audio
Hi all. Recently dug out my old Technics TT and broke out some old vinyl. Then bought a Sony PS-X75 (which was what I wanted back in the day) and a Technics SL1200MK5. My vinyl was always immaculately maintained, and doesn't really need a deep cleaning from one of those new vacuum machines. (I'm looking a t a DIY design, however, just in case.)
I use a Discwasher D4 brush to dust the disk down before playing and am out of solution to moisten it. Anyone have a home brew recipe they can share?
My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
Polk LSiM 702s x 4 on the Ceiling Atmos speakers
Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
Denon X3700H Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2100/NZ7 projector
Silver Ticket 135" microperf AT screen
Berkline 090 electric recliners with Aura Bass Shakers
  • george daniel
    george daniel Posts: 12,096
    edited June 2009
    do a search here for tergitol,, some of us got in on a group buy,, personally,,I love the stuff,, get's em' clean,and a little bit goes a loooong way.
  • dkg999
    dkg999 Posts: 5,647
    edited June 2009
    The D4 formula is available if you do some internet searching.
    DKG999
  • pearsall001
    pearsall001 Posts: 5,400
    edited June 2009
    Brillo pad w/ Comet.
    nooshinjohn Posts: 26,182
    edited June 2009
    media blasting is more effective than comet and brillo
  • jm1
    jm1 Posts: 618
    edited June 2009
    DO NOT USE Tergitol if you don't have a vacuum machine to remove it from the LP surface. It is meant to be removed from the disc AND followed by a water rinse. Very important!
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • davidfmartin
    davidfmartin Posts: 106
    edited June 2009
    I use Phoenix from sleevetown.com. 25.00 for a gallon and it works great.
    http://www.sleevetown.com/vinyl-cleaning.shtml
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    I use;
    1. Vinyl-Zyme Gold
    2. MFSL Super Deep Record Cleaner
    3. MFSL Super Record Wash
    4. VPI Record Cleaner
    . . . to initially clean new and used records.
    I use the Tergitol combo and distilled water rinse to clean each record before each use. All of these cleaners are used with different brushes on a VPI 16.5 record cleaning machine.
  • thsmith
    thsmith Posts: 6,082
    edited June 2009
    3/4 gallon distilled water, 16oz 91% isopropyl alcohol and 5 drops of Triton X-114.
    Record cleaning brush, old TT and modified shop vac to remove solution.
  • george daniel
    edited June 2009
    jm1 wrote: »
    Good point,thanks for the clarification.
  • Fongolio
    Fongolio Posts: 3,516
    edited June 2009
    Tergitol S-3 and S-9 combo with distilled water on my Nitty Gritty 2.5 Fi followed by a rinse with distilled water. For really nasty stains I'll use a diluted solution of isoproyl alcohol and enzyme cleaner.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • miner
    miner Posts: 1,305
    edited June 2009
    1 part 91% isopropyl alcohol, 4 parts distilled water, 3 drops of unscented detergent. Simple and effective.
  • ckphoto
    ckphoto Posts: 121
    edited June 2009
    thsmith wrote: »
    This is definitely the best route to go but if your records are still exceptionally clean just get a anti static brush for now. Then before you know it you will be obsessed with the sound of vinyl and want a RCM.
    Mitsubishi WD-73736
    Pioneer Elite SC-05 :D
    Xbox 360
    Sony PS3 80GB
    Velodyne minivee
    Rti70s
    Csi40
    4-Fxi50s
    Monster PowerCenter HTS 3600 MKII
    Harmony One
    VR3 Posts: 29,762
    edited June 2009
    This thread is why I will never be into vinyl.
    lol
  • jm1
    jm1 Posts: 618
    edited June 2009
    lol
    Thanks! That leaves more LPs for us to collect. lol
    Arthur Schopenhauer
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited June 2009
    miner wrote: »
    Close to the formula I know, but no detergent added. As an addendum, give a sweep with an anti static brush. Dig in somewhat with the brush, as the grooves are very fine and apt to passed over if not somewhat pressing down with it. Obviously get a brush with very fine hairs....
    Vinyl by its nature will establish localized electrostatic charges (pops) that are very difficult to remove. It's a material issue. Earlier LPs made from lacquer did not have it.
    The simple solution that used to be used was A) clean, B) play once to remove any physical clutter from the grooves, C) clean again and D) ALWAYS record the 2nd pass through onto analog tape. Then put the vinyl away for archival/backup purposes; use the tape for general playback.
  • ckphoto
    ckphoto Posts: 121
    edited June 2009
    lol
    I think vinyl is a labor of love and the sound quality is worth the effort. Your system is impressive I would love to hear some vinyl on it.
    Mitsubishi WD-73736
    Xbox 360
    Sony PS3 80GB
    Velodyne minivee
    Rti70s
    Csi40
    4-Fxi50s
    Harmony One
