Model 7A Like I've Never Seen
skrol
skrol Posts: 3,451
edited May 2009 in Vintage Speakers
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
  • danger boy
    danger boy Posts: 15,722
    edited May 2009
    nice pair of monitor 7A's. just a guess.. but i would think they were from about late 70's early 80's.. more likey 70's. for some reason.. I"m thinking 1977, or 78. but that's just a guess. 7A were built from 1977 to 1982
    PolkFest 2012, who's going>?
  • nadams
    nadams Posts: 5,877
    edited May 2009
    Yep, an early model. All of the early monitors used the velcro pads for the grills. They then switched to the more common plastic posts somewhere along the line. I'm surprised those 7a's have the coated drivers. Usually when you see the velcro, you also see uncoated paper drivers.
    Ludicrous gibs!
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2009
    I'm guessing those were made in 1977-early 1978. My 7A's were made in 1978 and have the plastic posts for the grilles.
    As Sal said, those aren't the original passive radiators.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    mhardy6647 Posts: 35,029
    edited May 2009
    They look to be identical to mine (although mine are in a simply lovely rosewood vinyl!), if they have two fuses. Mine date to 1977-78 (I bought them as demos in 1978). I can check the S/Ns at home tonight if anyone is really interested.
    edited May 2009
    Ok.
    Here's the question....peerless tweeters precede SPL1000, 2000, 2500, 3000. Is the peerless the 'superior' tweeter. If so, then why the SPLs? If not, why does everyone around here foam at the mouth when they hear 'peeeerlessss'? Excuse the emphasis. But I've been trying to unravel this tweeter labyrinth--then of course we have the tri-laminates? And the 'return' of the silk dome in the M series which 'somehow' Polk 20+ years later managed to make inferior to the peerless? What's that about. Good marketing? Technological regression...?
    cnh
  • comfortablycurt
    edited May 2009
    Peerless tweeters are badass. I absolutely love mine. They're generally considered the best tweeter that was put into the Monitor series.
    The Peerless tweeters weren't made by Polk, which could be part of it, they were made by Peerless. It seems that Polks in house tweeters from that era lacked in some certain areas, which is why you see so many people updating their vintage speakers with the RDO replacements.
    I don't really know the technical reasons for them being better, but these tweets have a very distinctive, smooth, airy sound quality.
    edited May 2009
    cnh wrote: »
    Ok.
    cnh
    Listen to one sometime.
    edited May 2009
    I'll try to of course. But the question remains...why aren't current Polk silk domes up to peerless quality? That seems a bit negligent to me.
    cnh
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    Those are the original PR's.
    Ben
  • comfortablycurt
    edited May 2009
    ben62670 wrote: »
    Correct me if I'm wrong, but all of the 7A's I've ever seen(mine included) have the gray paper gasket around the outer edge of the MW and the PR.
    These speakers have the gasket around the MW, but not the PR's. They're probably the same model of PR though, so I doubt it makes much of a sonic difference.
    edited May 2009
    This is one of my 7As, FWIW.
    S/N on the one in the photo is 04900.
  • comfortablycurt
    edited May 2009
    Nevermind...I've found a few pictures of the older 7A's, and they all look like that one. I guess the earlier ones didn't have the paper gasket around the outer edge of the PR's.
  • danger boy
    edited May 2009
    the rubber surround on the passives from the OP do not look original to me either. the rubber seeems to robust if you ask me. I could be wrong.. but they don't look original
  • Hawking821
    Hawking821 Posts: 8
    edited May 2009
    yea i think danger is right they dont look original.. i would check first before you buy sbiggrin.gif
