LSi9's nearfield on a desk
ph0rk
I know that the general consensus is that most receivers can't drive the LSi9's adequately, but what about in a nearfield application? probably 2-3' from the listener, on a desktop (likely with mopad isolation). Would something like a pioneer a35r or yamaha rx-397/497 work? (both 4-ohm stable two channel amps, the pioneer is lacking a tuner but I have no real preference there).
We're only talking 65 full bandwidth watts into 4 ohms w/ the pioneer, a bit more with the yammies.
Doable, or a waste of money? I like the idea of a more polite or laid back top end - I tend to cut about 6 dB or so of treble with the tone controls for my Bostons, depending on the room (like the detail, don't like the sizzle). I currently have an older rx-v series yamaha that is temporarily in the office until I settle on a replacement, and I think it paired the VR-M60's will lead to treble fatigue very fast.
Post edited by ph0rk on
Why not go for 7's instead? Those will be easier to drive and in a nearfield ap you wouldn't be too worried about the extra bass from the 2nd driver.
I think they might work as near-field monitors; but on a desktop? They're just so deep (17-18") that it might be a problem. At least it may look a little strange. I guess it could depend on how big your desk is.THE MAN-CAVE 5.1 CHANNEL A/V RIG
Sony KDS-60A3000
a/d/s/ HT-400LCR (3)
a/d/s/ HT-300 (2)
Velodyne DLS-4000R (2)
Pioneer Elite VSX-55TXi
Pioneer Elite DV-47Ai
Sony BDP-S300
Sony SLV-779HF
DirecTV HD sat. receiver
MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
Adcom GFA-5500
Bose 901 Series VI
NAD C-165BEE
Slim Devices Squeezebox Classic
TEAC CD-RW890
Technics SL-BD20D w/ Audio-Technica P34
Akai HX-A3X -
Are they really any easier to drive given they have the same efficiency? I've never had a MTM bookshelf before and I'd like to try it out.
The desk has some space behind it, the speakers will end up being roughly flush with the monitor bezel (and I hadn't planned on using the space behind them, anyway).
the VR-M60's are already 12" deep (and 11" wide!), so deeper yet more narrow speakers will actually free up a bit of space. -
LSi 7's."The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
The LSi9's need space, I think you'd be wasting your money. Not to mention how deep they are. I think the 7's would be a better match for what you're trying to accomplish.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
+1...the lsi9's need space, i think you'd be wasting your money. Not to mention how deep they are. I think the 7's would be a better match for what you're trying to accomplish."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
