Lsi15's - Upgraded Xo's by Ben.
jerryj12
I hate to see the go. They sound fantastic. The Xo's were upgraded by our very own Ben. ( sonicaps and mills resistors ) There is one small blemish on the left rear top corner ( about the size of a dime ) of the right speaker, not bad but i need to disclose.
Driver Complements
Subwoofer 1 - 8" Diameter (20.32cm)
Polymer composite cone with rubber surround (shielded) 1 - 10" Diameter (25.40cm)
Mid/Woofer 2 - 5-1/4" Diameter (13.34cm)
Dynamic Balance with Aerated Polypropylene cone, cast basket and rubber surround (shielded)
Midrange 2 - 5-1/4" Diameter (13.34cm)
Dynamic Balance with Aerated Polypropelyne cone, rubber surround and cast aluminum basket (shielded)
Tweeter 1 - 1" Diameter (2.54cm)
Dynamic Balance Ring Radiator (shielded) 1 - 1" Diameter (2.54cm)
Electrical
Overall Frequency Response 22Hz - 27kHz 20Hz - 27kHz
Lower -3dB Limit 30Hz dB 30Hz dB
Upper -3dB Limit 26kHz dB 26kHz dB
Nominal Impedance 4 ohms 4 ohms
Recommended Amplifier Power 20 - 250 w/channel 20 - 300 w/channel
Efficiency 88 dB 88 dB
Crossover
(mid-high array) Driver 1: HPF at 150Hz 6dB/oct, LPF at 800Hz 12dB/oct.
Driver 2: HPF at 150Hz 6dB/oct, LPF at 2.4kHz 12dB/oct.
Tweeter: HPF 2.4kHz 18dB/oct. Driver 1: HPF at 80Hz 12dB/oct, LPF at 800Hz 12dB/oct.
Driver 2: HPF at 80Hz 12dB/oct, LPF at 2.4kHz 12dB/oct.
Tweeter: HPF at 2.4kHz 18dB/oct.
Crossover
(subwoofer) LPF at 150Hz 12dB/oct. LPF variable 60Hz - 180Hz 12dB/oct.
Inputs Dual sets of gold-plated 5-way binding posts for bi-amp/bi-wire hookup Dual gold plated 5-way binding post speaker inputs. Line level subwoofer input (filtered) and LFE subwoofer input (unfiltered)
Outputs Line level passthrough
Dimensions
Cabinet Size 45-1/2" H x 8-5/8" W x 13" D
(115.57cm H x 21.91cm W x 33.02cm D) 49-3/4" H x 8-5/8" W x 17" D
(126.36cm H x 21.91cm W x 43.18cm D)
Footprint Size 9-11/16" W x 13-3/8" D
(24.61cm W x 33.97cm D) 9-5/8" W x 16-3/8" D
(24.45cm W x 41.59cm D)
Enclosure Type
(mid-high array) Vented with dual ARC ports Vented via dual ARC ports
Enclosure Type
(subwoofer) Vented via floor-coupled Power Port Vented via floor-coupled Power Port
Asking 650.00 ( because of the blemish )
Local pick up please.
Driver Complements
Electrical
Crossover
Crossover
Dimensions
Enclosure Type
Enclosure Type
Post edited by jerryj12 on
I have heard these,, and I have never heard a pair of 15 sound./image like these,,somebody better jump on these ,,quick,.JC approves....he told me so. (F-1 nut)
I already chewed Jerry out for the price. I think there is about $300 in caps and resistors in there...Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Yeah-that's one helluva price esp. considering the upgraded XO parts.____________________
Pool: Atrium 60's/45's -
DAMMIT. Why don't you live on the GOOD coast?SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
I listened to these for about four hours,, they sounded grear,ss or tube,, the bass was tight and controlled,, not loose or boomy,,the mids and highs just blended so well without any "harshness" or being bright. I think that considering the facr the the x-overs are completely modded/upgraded,, this price is a STEAL for the speakers. Somebody better jump on the quick,as they are not your "garden variety" 15".JC approves....he told me so. (F-1 nut)
if you were within driving distance, I'm pretty sure they'd be a perfect match for my HT... Oh well... guess I'll have to get a set some other day.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
if anyone wants stock speakers - I will be glad to purchase the crossovers from you for $100 and ship you my factory crossovers to replace them with.Mains.............Polk LSi15 (Cherry)
Jerry has a special friend....
And you know WHO that is...... Will we see you this weekend? -
bumping out of principal, someone should snag these.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
Are U Freakin' kidding me? These are still here?____________________
Totally agree. I sold mine Lsi15 recently but would jump on this without hestitation if this was local. This is a steal.Main Gear
Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7. -
How much would I have to pay for shipping UPS to me in Japan?Shoot the jumper.....................BALLIN.............!!!!!
Ship em' Jerry,,one step closer to the 9's--good luck with the sale.JC approves....he told me so. (F-1 nut)
george daniel wrote: »Ship em' Jerry,,one step closer to the 9's--good luck with the sale.
Ok, ok I give I will ship 'em. ( With you help packing of course:) )
Buyer pays shipping costs.
Hey! Maybe we can get 'em on the lightman express. Wink Wink:D -
Now that sounds like a plan,, "lightman express",, safe as a baby in a mothers arms.:)JC approves....he told me so. (F-1 nut) -
anonymouse wrote: »Sherardp is first in line.
How much would shipping be to 46368?
Working on that now.
Also, did Ben do the LF section as well or just the HF?
Yes he did both sections.
I will Pm you when I figure the shipping. -
Sold..... to vmaxer. Nice to meet you sir. I foresee a few road trips in your future.:D
Congrats to both of you,, those are the finest pair of LSI's that I ever heard.JC approves....he told me so. (F-1 nut)
The pleasure was mine. I hope to see you more in the future!!:cool:I can't wait to try these out at home, they sounded absolutely great in your system!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I guess the shipping was too much for them?
I think that shipping these would have been somewhat risky,and cost prohibitive,, thus negating the "good deal",, as they already had suffered one corner "ding". We listened to these with my Quicksilver M-80's,,and they were fantastic,, which surprised me,,as I could never get my 15's dialed in with solid state,, much less tubes,, yep,, the buyer got a good deal,,and given the right gear,,will have a stellar 2ch system,if that's the path he chooses. I'm sure that the sonicap crossover did not hurt either.;)JC approves....he told me so. (F-1 nut)
