AMP POWER for LSI Surrounds
JuanR
What amp do you guys recommend to power LSI surrounds?
Post edited by JuanR on
I'm running my LSi 7's and LSi F/x's off my AV receiver. Speaker wire is 30 ft length, 12 guage. I eventually plan to run 30 ft interconnects with shorter speaker cable.
Whatever amp you run, it should be 4 ohm stable. I wouldn't think you would need more than 150 watts, unless you're trying to use SACD or DVD-Audio with full power to all speakers.LSi15's, LSiC, LSiF/x's, LSi7's, vr3 crossover upgrades, SVS PC-12 Plus, SVS SB-16 Ultra, Marantz AV8805, Parasound amps, LG OLED65C9PUA, Clarus Crimson, Signal Cable, Atlas Cable, Shunyata and Synergistic A/C conditioning, dedicated Cardas 30A and Furutech 20A AC lines, Box Furniture, Solid Tech ROS, Symposium roller blocks -
I'm running my LSi/FX off of my NAD T765 AVR (conservative rating of 80w). Plenty of juice for HT & music as far as my ears are concerned."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
