Sunfire Cinema Grand Signature Amp's
  • BlueFox
    BlueFox Posts: 15,251
    edited March 2009
    metal83 wrote: »
    Ohhhh ok then, i see what you meant now.
    I was unaware that they didn't make 2 channels amps anymore.
    From what I see on their web-site they are focused on HT and/or surround sound. While there is nothing wrong with that, I think a high-end manufacturer should also have some two channel products. After all, at least for amps, it mainly is reducing the number of channels, and rearranging the packaging. Of course, the main thing from my perspective is a lower cost for the same technology.
    nooshinjohn Posts: 25,931
    edited March 2009
    TNRabbit wrote: »
    SherardP is correct; the dual RCA INPUTS on the Sunfire are NOT for current/voltage sound, nooshinjohn; there are OUTPUTS for the MAIN speakers that have current/voltage taps (tube/ss sound). The dual RCAs inputs are for daisy-chaining from one channel to the next, OR to a different amp if you want. You go IN to one RCA & can go OUT of the other, either into another CHANNEL on the Sunfire, or to another amplifier.
    I go into one RCA from the pre/pro, then out to the next channel RCA in order to biamp my speakers.
    Does that make sense to everyone?
    I stand corrected... I got the input connections crossed up with the output/speaker connections. I will punish myself appropriately:eek:
