Need Help: iPod Chargers & Int'l Travel
I-SIG
Folks,
I'll be taking a long-ish trip to South Africa in October. As such, I need some serious power to make it across the US and Atlantic with enough juice in my iPod.
Kensington makes a nice looking battery back-up, but it $70 and I'm pretty skeptical of 100 hours of playback.
Most of the chargers I've seen are fine on 120V or 240V, however South Africa uses an oddball type M plug. Most of the adapter kits I've seen don't support the South African pattern.
Any ideas or suggestions?
Thanks,
Wes
Thanks,
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
I use this for my trips to Asia....
http://www.amazon.com/Maxell-iPod-Backup-Battery-Pack/dp/B0007XCT18/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1236550010&sr=8-1
