sda's
found what is described as 2 sda 2B polks ...on local craigslist....says he has original cross link cable and manual.....says they sound great....and will demonstrate .....$300 for the set.....i don't know anything about these speakers...is it a good deal??.....i know that you can't tell by a picture.....but they look to be in great shape
Post edited by chemical on
which version,, studio, or end caps,, pin/blade,, 200-250 is a fair price.JC approves....he told me so. (F-1 nut)
george daniel wrote: »which version,, studio, or end caps,, pin/blade,, 200-250 is a fair price.
i don't know....anything other than sda 2b.....thanks -
go see them,,if they are the 2 mid/1 tweeter version, dep on cond,, 100-225 is your range of a fair price,,let us know what happens--good luckJC approves....he told me so. (F-1 nut)
from the pic it appears they have 1 tweeter towards the top of the cabinet,then 2 smaller speakers side by side under the tweeter,then a larger speaker at the bottom of the cabinet.
no reply from the seller yet,but i'll keep trying.i'll let you know what happens.thanks for the info
